Fuse blows when I plug it in
There can be several reasons. It would help me to know what make and model, but heres a start.....1} Make sure your using the correct fuse.2} Look for any debris or items which have entered the unit that could be shorting out the circuit. Also look for loose connections or wire spades that have come loose and shorted 3} Next see if the combustion and convection blower is turning freely. They should spin with ease. If in doubt, make a test cord from an old extension cord and try the blower directly by DISCONECTING it from the stove wiring and hooking the test cord to it then plug into a power strip carefully.4} Check the auger... Can you wiggle it around with your hand? If so then use the test cord in the same fashion as the blower. Augers tend to jam up and that can blow the fuse depending on the make of stove. 5} Look at the igniter and wire to assure that it is in visibly good condition. These are some good places to start. If none of these are help, it may be worth while to call a repair tech or manufacture help line. Be prepared for a long hold if you call during peak winter season. Good luck.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/william_c9458c4c1f94e482
