Question about ATI RADEON X1650 Xt, (256 MB) Graphic Card
Hopefull plea before i go mad
Ive installed x1650 pro into my machine which previously ran ut and cod etc with a nvdia 660gt with no problems. with this card machine runs perfectly as before. i installed the new ut demo and cod 4 demo, i get the message ut/cod4 demo exe has encountered a problem and needs to close when trying to start either. To further compound the problem a fresh install of the xp plus package wont run either, monitor keeps doing the clicking thing, going black and from what can be seen of the desktop, resolutions seem to change between clicks. Tried varying driver packages and the catalyst center reports no problems.card is running full 8xagp speed. Card happily powers call of duty one and 2 etc.Further, an older machine fitted with the nvdia card runs all three without a glich.Am i missing something here? Really dont want to have to resort to the hammer... HELP!
  • 99 Answers
Re: hopefull plea before i go mad
Sounds like a driver problem to me. I recommend removing all video drivers from the computer, restart the computer, then install the newest catalyst drivers. The error saying that the exe has encountered a problem and needs to close may not be fixed by this. I would recommend re downloading them or getting a new copy from some where else.
Posted on Nov 12, 2007
0 characters
3 Points
Start up problem...
you are having compatibility problems with the motherboard and the new peace of hardware.
return the product as in op or defective part and i would recommand a different product and see if you have the same problem.
Feb 25, 2009 | Sapphire RADEON® X1650 PRO, PCI Express...
ATI x1650 Pro Stops!?
For this card they recomment at leat a power supply rating of 450 watts. If you have lower than this then I would suggest upgrading the power supply. A 550 watt psu is reasonably priced and should give you plenty of power for future use. Hope this helps.
Oct 17, 2008 | ATI RADEON X1650 Graphic Card
ATI RADEON X1650 Pro Problem
The graphics card might not be working in sync with your processor. Get it checked WHY this is happening. Probably a faulty connection somewhere. See if you can find one before getting it checked.
Sep 13, 2008 | ATI RADEON X1650 Xt, (256 MB) Graphic...
the card you have is a PCI express 16X your board is for PCI express 8X. I think some cards can run at a slower speed but I believe you have the wrong card for your board
Jul 29, 2008 | ATI RADEON X1650 Graphic Card
ATI X1650 Pro, AGP
i had a simer problem if it is connected with the HD compisit cable
you need to go in to the catalyst control center under advance view you have display options were it will list the 2 diplays and have a third display in a gray box under it
right click on the third display and go to swap that should resolve the issue
May 21, 2008 | ATI RADEON X1650 Graphic Card
My monitor freezes
since you have laready checked the videocard to be working on your friends pc, the problem may be on your motherboard.
try to do some tweaking on the BIOS and if that will not help, check your directX and softwares installed on your pc. check also if your pc is in its most optimal settings.
Apr 24, 2008 | HIS RADEON X1650 Pro iSilence II Dual,...
SAPPHIRE X1560 Pro (ATI) issue with Vista
ya tuff on that 1650 chipset i would sell it on ebay get yurself 1950 ok or 8800 best bet for vista those 1650s off new egg sumtimes are fulty chipsets in vista its tuffer yet bestto buy ati brand also
Jan 06, 2008 | ATI RADEON X1650 Pro, (512 MB) PCI...
ATI RADEON X1650 Pro, AGP Graphic Card 512MB compatibility
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
Oct 13, 2007 | ATI RADEON X1650 Graphic Card
ATI RADEON  X1650 Xt, (256 MB) Graphic Card Logo
67 people viewed this question
Top ATI Graphics Cards Experts
Brian Sullivan
Brian Sullivan
Are you an ATI Graphics Card Expert? Answer questions, earn points and help others
