Question about Dell 1700n Laser Printer
I swapped Photoconductors from 2 other 1710's; no go. Reset?
Is there a way to reset the printer so that it doesn't think that it needs a new Photoconductor (aka Fuser)? I have pulled one from a printer that has 50% life left in it, but my problem printer still thinks that the photoconductor is 'Empty'.
Problem
Dell 1700 printer prints out a page announcing that “the photoconductor has reached its useable life and it needs to be replaced for a new one”. You replace the photoconductor for a new one and the error light is still blinking and the printer keeps on printing the above mentioned page.
Solution
Steps to Reset the Photoconductor:
  1. Power off printer
  2. Open the front cover.
  3. Press the continue button; while pressing the continue button power on the printer and wait (still pressing the continue button) until the error led is solid, then release the continue button.
  4. Close the front door, all light should be solid.
  5. Wait until POST finishes.
  6. Press the Cancel button 4 times slowly, the toner led should be solid.
  7. Press the Continue button until all lights go up and down, then release; the Toner Low led is solid.
  8. Power off printer and then back on.
  9. Press continue button once, print a test page.
  10. Check the information about the photoconductor in test page, it should display an OK status.
Note: if these steps don’t work for the first time repeat three times. If still the steps don’t work, the printer needs to be replaced for a new one.
Posted on Aug 04, 2009
    Sergeant:
    Champion:
  • 233 Answers
Turn it off and om. It might work.
Hope this helps
Posted on Jun 26, 2009
  • blablablabl Mar 04, 2011
    See page 62 of the user manual, (google Dell 1710n User Manual)
How photoconductor unit to be set
Sorry but photoconductors are handled only by technician, tis is to avoid damage and correct handling it is set to its standard settings to have a good copy quality. before inserting or setting the photoconductors the machine is to be cleaned thoroughly. so let it be handled by a photocopy technician even you pay or not for its services, it is worth it.
Sep 06, 2011 | Gestetner DSm725 Color Copier
There is no method to reset black drum kx-mc6020?
if your talking about the counter, if it doesn't recognise a new cartridge, then most likely the printer needs to be put into service mode to have the counter reset, you may have to call in a Panasonic service man to do it for you.
Jul 07, 2011 | Panasonic KX-MC6020 All-In-One Laser...
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Computer doesn"t reconize printer because
Hi, I believe you have to update your printer driver (software) Then restart your computer. Good luck.
Jun 14, 2011 | Office Equipment & Supplies
Printer will not print, error message photoconductor kit error end of life problem, even though kit has been changed
Most of the photoconductors reset automatically through some sort of electrical trip. If this is already broken when it comes in, it of course will not reset. It will still work fine but you need to manually reset the count. Look up in the manual on how to do this or provide what type of printer it is.
Dec 08, 2010 | Computers & Internet
Lexmark c532n prints smudges on page
The problem could be caused by the photoconductor units. Try to swap the affected photoconductor units (like swap the magenta with black and cyan with yellow). If problem still occurs, then the photoconductors need replacement. I suggest you contact Lexmark Technical Support for assistance. Thanks
Jul 26, 2010 | Lexmark C532n Color Laser Printer
How do I replace the transfer belt on a Lexmark C522n printer?
To replace the transfer belt open the front door, as if you were to replace the toner. Once the front door is open then remove the photoconductors one by one make sure not to touch the surface of the photoconductors also make sure not expose them to light for a long period of time. Once you remove the 4 photoconductors then you should be able to see the transfer belt, just unplug the connector at the top, then release the two plastic flaps on the side and lift the transfer belt. That should be it.
Jan 05, 2010 | Lexmark C522n Laser Printer
Ink Low message after installing new cartridge
There is no way to actually "reset" the counter. IF your MP170 has a RESUME/CANCEL button, Press and hold this button for about 7 seconds to bypass the counter (The PAGE FEED button will work for some other models). If your printer doesn’t have this button, you may bypass the counter by turning the printer OFF. Now hold down the RESET and turn the printer ON. Keep holding the RESET until the printer boots and initializes. When the display says, "INK VOL UNKNOWN" you may release the RESET and begin printing in the usual manner. You may need to start the printer in this manner each time, or the printer may remember this setting. Canon was experimenting during this time so some of the same models have different buttons and bypass tricks. Hope this helps.
I hope this helps you.
Sep 13, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Printer Reset instructions for HP 564 inkjet cartridge.
Dear, this is basically an auto generated message based on system registery keys, if you want to bypass the message, then there are two ways.
1. put another cartridge in the printer and try to print, after than install the previous (original) cateridge, this will doge the printer as a new cateridge, you problem will be removed. but if you don't have another similar cateridge at hand then follow the step 2 given below.
2. Uninstall the driver, unplug the printer, restart the system and reinstall the printer dirver again, your problem will be removed.
Best regards.
May 26, 2009 | HP Photosmart D5460 InkJet Printer
Reset ink counter canon mp240
Press the red button in the right bottom, the one in witch is a red triangle. Press it for 15 seconds. Ciao!
Feb 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Dell 1700n Laser Printer Logo
971 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
