Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Hi i have a hayward 400h and it reads 1f or if starts then shuts off and smoke comes off the top can u help
If = ignition failure. there's a troubleshooting chart in the hayward manual.
Posted on Jul 18, 2009
What is a 1F code on the hayward pool heater
The code you are referring to is actually IF, not 1F. It stands for ignition failure.
If the control exceeds the maximum number of ignition retries or recycles the heater will shut down and go into lockout. Automatic reset is 60 minutes.
Aug 09, 2014 | Hayward Pool & Spa
Hayward H250 pool heater will not light
see if pressure switch full voltage both sides or hi limits
Apr 26, 2013 | Hayward Pool Products Hayward H250 250k...
Why us black soot coming out hayward heater
check gas pressure if incorrect it will soot up and overheat and start to self destruct correct gas then have heater cleaned
Sep 15, 2012 | Hayward Pool & Spa
1F Error Code on Hayword Heater
IF stands of igniton failure. Many things can cause this. Most notable, is a clogged or dirty burner orifice. The two middle ones are the most important. But i would clean them all out. They remove with a 5/16" wrench. Improper gas pressure could also cause this. However, you need a special tool, a manometer, to read this.
May 05, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
I add diesel in petrol engine (Rx 400h) and started driving. Now it doesn't fire the engine. What should I do now?
hi,
we have read your problem and understood that your engine is not starting now.please call a local repairman to drain all the diesel and clean the engine carburetor using petrol only.
i make it clear that the engines for petrol and diesel are totally different since the chemical combination of the liquids are also different.they are different like chilli sauce and tomato sauce.diesel cannot be used in petrol engines since they are designed to burn only petrol.i believe you have understood the facts and the differences between the engines of petrol and diesel.thank you, have nice day
Feb 11, 2010 | 2008 Lexus Rx 400h
I have a h400 gas heater. keeps shutting off reading 1F code
If the heater is cycling on and off continuously the problem may be a dirty filter. Try backwashing and rinsing the filter before anything else.
Jun 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Smoke or vapor coming from new h400fdn hayward pool heater.
Not at all uncommon. New heaters have to glaze over the file tile in the burner chamber and will often smoke and smell during the first week or so of operation.
Using a mirror, check to see that your flames are about 4" proud of the burner tubes when running. As long as they are and the color is a nice blue with little to no yellow/orange color, the heater is fine.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
860 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
