Question about Frigidaire PLMV168 Microwave Oven
Turn table not turning
It still seems to heat just fine but i turned the turntable off and now it wont come back on. Any help would be appreciated. thanks
  • 1 more comment
  • Anonymous Nov 21, 2007
    My turntable is not turning either, I tried to push the button on the keypad but it still does not help.
  • refix Dec 26, 2007
    I have PLMV169DC . Turntable doesn't work. Touchpad On/Off indicator works - no clicks. Unplugged & left for several minutes - no soap
  • tristyberry Sep 25, 2008
    My turntable is not turning, the turntable button does not click but does change from "on" to "off" when pressed.
  • Frigidaire Master
  • 9,098 Answers
When you press the turntable pad do you see an indicator changing in the display?
Do you hear a click when you press the pad?
If not, try opening the door then closing it and trying again and also try unplugging it for a few minutes, resetting the clock, then trying again.
If all that fails, you probably have a bad relay or connection on the control board, or a bad turntable motor.
Please write back with more details if you need further help.
Also, we do repair these control boards in case you need that help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 18, 2007
the motor for the turn table has broke and when it doesnt turn it wont heat?needs new motor or new microwave
Apr 07, 2016 | Microwave Ovens
Sharp - Food not heating up but all is lit up and turn table turns
Hai my friend, if its not heating you must open it at the back and check your fuse on top for contuinity using amultimeter it must be on abuzzer and if its fine there is other fuse covered with normal black cover connected to the cspacitor also check it, if this two fuses are fine check your capacitor if its fine check your magnetron for contunuity of 0,2 ohms but normal if its not heating its fuse, thx
Sep 13, 2014 | Sharp R959SLMA 900 Watts Convection /...
Turn table in microwave wont turn
Repairs are expensive. New microwaves are cheap. But you don't have to spend a dime on either. If your microwave turntable stopped spinning, here's an easy way to try and fix it. And all you need is some warm, soapy water and your own two hands. You don't have to be an appliance expert to troubleshoot a seemingly broken microwave turntable. You might find that all your little Zappy needs is a checkup and a good, thorough cleaning. If you follow these steps and find that your microwave still isn't turning, it probably means the motor has spun it's last spin. Then it's time to retire old Zappy. Unplug the microwave. Safety first, kids. Remove the glass tray and the circular turntable guide. Wash them both in warm, soapy water to get rid of anything stuck. Pay special attention to the rollers on your turntable guide, making sure they're able to spin freely. Clean the internal cavity. Make sure to check your microwave's center cavity to make sure it's free of movement-hindering (and gross) leftover food. Check that the drive bushing is working. Make sure that the drive bushing, the plastic mechanism in the bottom of the microwave's interior that the glass tray turns on, isn't worn out or split in two. If it is, you'll need to have it replaced. Put it back together. Put the turntable guide back into the circular groove. Place the glass tray turntable over the turntable guide and onto the drive bushing. Adjust until the drive bushing should fits perfectly into the grooves of the glass tray. Test it out. Zap a mug of water for a short bit to see if you fixed the problem. Do not run the microwave without anything in it.
Aug 05, 2012 | Microwave Ovens
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
Turntable in microwave does not turn. is it dangerous to keep using it?
hi. ther is no problem using your micro with the table not turning. as long as it still heats. the turn table is usually the first to go. i have had a couple like that and used them for a long time with no problems. you should be fine. hope this helps ease your mind. have a good day!
Jan 15, 2011 | Microwave Ovens
Turntable not turning
you should be able to repair this your self the turntable motor is fairly easy to get does sound as though your motor has gone bad.
Jan 31, 2010 | Dacor DCM24 Convection/Microwave Oven
Em-s3577s uk 2 wont turn
Remove the turntable plate and check the motor coupling gears underneath, if motor coupling is fine, then replace the turntable motor.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 19, 2009 | Sanyo Microwave Ovens
Microwave turntable does not turn
In microwave ovens, I have had the turn table motor unit become defective, or the power source to it has failed.
Jerry G.
May 15, 2009 | Hotpoint RVM1435 Microwave Oven
Russell hobbs microwave turntable wont turn
Is there an option via the Help or Custom Help to turn the turntable off and off?
This feature is common in over the range models.
Otherwise, it may be a bad motor.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand:
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven, as you're looking up from the stove top.
Please write back with your model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Microwave Ovens
Frigidaire PLMV168 Microwave Oven Logo
64 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
