Question about Microwave Ovens
My kenmore elite microwave is loosing power
My kenmore microwave is loosing power. it's only 7 years old and recently it takes 2-3 times as long to cook something in it. I can't see any food buildup over the grills.
  • 54 Answers
I'm afraid the magnetron (most expensive part - generates the microwaves) is on its way out. In most cases, it doesn't pay to repair it - unless the replacement would cost over $200 and/or hard to find the right size for built-in. I would vote for replace with new - you've had a good run for the money, but this might not be the only problem that develops soon. my kenmore elite microwave is loosing power - wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Posted on Jun 26, 2009
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Kenmore elite microwave troubleshooting
My GE microwave buzzes at times but otherwise works just fine.
Jan 20, 2014 | Microwave Ovens
What does F-7 error code on Kenmore Elite microwave mean
That's a problem with the inverter or another high voltage part.
Dec 24, 2012 | Kenmore Elite Over The Range Microhood...
Kenmore elite countertop microwave/convection oven
Time for a new cover plate or a new microwave. Depending on the age of the unit, the part may not be available anymore.
Jul 06, 2017 | Kenmore Microwave Ovens
Display needs to be replaced on a kenmore elite microwave
Try managemyhome.com. I have a Kenmore Elite convection microwave and found the manual.
Jul 03, 2009 | Sharp R-1750 Microwave Oven
My kenmore ELITE 721.64282 microwave/convection just stopped
I just had the exact same problem. :( Did you find anything out?
May 23, 2009 | Kenmore 63792 Microwave Oven
Have a 4 1/2 year old Kenmore Elite Untra Wave Microwave Hood Combination. Recently got an F-9 error code after about 10 seconds. Tried unplugging for over an hour and then plugging back in, but got the...
The F9 error code indicates a failed inverter. If resetting the unit does not help you will need to have the inverter & harness checked.
http://media.fotki.com/1_p,wbgdfgsrsttwqwbxgtqsskgwtqkq,vi/kgdfkfrkkxkfdtftrfb/1/1303472/5961857/image45625img-or.jpg
This can sometimes by caused by a power surge or glitch through the electrical lines.
You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Plug it back in and see if the fault code returns.
If it does, then you have an internal component failure that will need to be serviced by a technician.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances.
Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged.
A microwave radiation leakage test must be performed on the unit following any internal component repair.
It does not ALWAYS indicate a inverter control board problem however in other brands/models.
LG's service manual (for an example) suggests the f-9 code could be due to line voltage, magnetron, inverter module, "Relay2", or a loose connection between door/magnetron/control pcb.
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case.
For example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possibilities.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Kenmore Microwave Oven Sudden Power Reduction
I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady, I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84 here.
Feb 14, 2009 | Kenmore 62622 Microwave Oven
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
Jun 06, 2008 | Kenmore 63793 Convection / Microwave Oven
Kenmore Elite taking long time to heat items
This is most likely a failing magnetron.
If it's less than 5 years old, Sears/Kenmore should cover the part, but you would still have to pay for a service call.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 16, 2008 | Microwave Ovens
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
