Question about Motorola Mobility E815
My e815 keypad seems dead - power button is the only one working
I can use a wired headset with the phone to make voice commands. I can turn the phone on and off. All of the other keys seem non-functional. I am able to transfer files and contacts to and from the phone with the adapter cable and Motorola Phone Tools. My warrenty is up so I don't want to go to Verizon. Can the keyboard be locked somehow? How can I unlock it if so?When I turn the phone on while depressing the camera button, the camera starts up but all buttons except the power button are inoperative. The phone works to make and receive calls using the wired headset, and it can receive text messages (though I don't see a voice command that lets me read them). Any ideas?
  • 210 Answers
If your keypad is indeed purposefully locked and for some strange reason there is no screen message to that fact, you can try pressing the Menu key then the asterisk key to unlock it. But, I'm afraid Marinora is likely correct. The E815 phones are quite problematic.
Posted on Feb 24, 2011
    Sergeant:
    Champion:
  • 233 Answers
Well, the phone is done with.
I dont understand why but most "motos"
are like that.
Sorry I couldn't help much...
Posted on Jun 26, 2009
  • nointegrity May 30, 2011
    Had a similar problem and found that if i held the green "send" button down for about two miutes, it beeped and "reset' itself or something and my key pad started working again! Alternativevley, another option I found that worked for someone is this (thanks to alltell tech support MoTohulligan)
    It seems like the tones aren't going through when you're on an active call. Try this: Menu>Settings>Ring Styles>Loud>Loud Detail> make sure Key Volume is set to 7. Then, go to the Initial Setup menu and change DTMF to Long. Then, go to Settings>Personalize>Sound Settings> make sure Number Dialing is set to DTMF.
    Basically, what these settings do is make sure that your phone is using tones when the keys are depressed and the volume is on. Based on your post, it appears that the keys are actually working so the settings are making it so, when you are on an active call, the tones are not being sent or something is wrong with your phone so that the tones are not being sent. If updating the settings doesn't fix the issue, you will probably need to have the phone repaired, if it is under warranty.
How to use voice dialer (svoice) with bluetooth on galaxy s5
Corded headsets do not have Bluetooth. Do you have a Bluetooth headset (wireless) handy to test the Bluetooth function properly?
Nov 04, 2014 | Samsung Galaxy S5
Keypad not fully working on a Motorola E815. The 5,7, 9 and send buttons do not work when pressed. All other features work and I can make calls by using voice command, so phone works otherwise, just not...
Hi. If you re attached to the phone you can purchase a new keypad. Otherwise you need a new phone.
The inner keypads of cell phones can become corroded after extensive use. Also as a result of being kept in a hot area.
Thank ou for using Fixya.
May 30, 2011 | Motorola Mobility E815
I need an instruction manual for my 222
what manual i have one i have no manual
turn on head set by holding power button
when paired with phone,come on it can't browse your phone for numbers
the side buttons are for volume
if you press the power button two times you will dial the last caller
or you may be able if you have set your voice commands
if you are paired but not connected you can press power button once and it should connect
Oct 01, 2009 | Plantronics - Bluetooth Headset Plus Base...
Even numbers do not work on keypad of Motorola E815
The keypad seems to be broken then, had the same problem on my Nokia 6230, some keys didnt work. I'd suggest you to take it to repair.
Aug 09, 2009 | Motorola Mobility E815
How to make a voice call
Are you sure the phone is voice command capable? To set up on the phone you must follow commands to repeat several letters, numbers & words. If you have done that then push the button on the headset & you should hear "say a command".
Jan 25, 2009 | Motorola Mobility H680 - Headset -...
Jabra vbt185z difficulties using voice commands
go to your phone tools and find voice command blue tooth and follow prompts . its all in the phone . the tooth is run by the phone. your blue tooth is only a reciever, the phone is the boss. good luck
Jan 15, 2009 | Jabra BT350 Bluetooth Headset Headset
My E815 'end call' key wont work. cant turn my phone back on.
the phone uses a complete keypad for all the buttons you may need to replace tne whole keypad flex assembly. if you can take apart the phone you can purchase the flex on ebay. if not contact your local cell phone tech or you con contact www.fixphonenow.com for a repair estimate.
Nov 08, 2008 | Motorola Mobility E815
MOTOROLLA E815
Here is a link for your phone at motorola.
If you cannot get there by just clicking the link, then copy and paste.
http://www.motorola.com/mdirect/manuals/e815VZW_9491A79O.pdf
Or just copy and paste the main www.motorola.com
Feb 24, 2008 | Motorola Mobility E815
Voice Dialing Issues
I am sad to say that the voice recognition failure is permanent on most of the E815 phones. Your phone will likely never support voice dialing again, even though the cause remains unknown.
I too had the peculiar problem of pressing the voice button and hearing a beep, but no voice prompt ("Say a command"). When I researched the issue, I found a plethera of similar problem reports. Very few reported recovery after simply restarting the phone. I even found one report of Motorola tech support giving up and instructing the owner of the phone to have it replaced.
Feb 14, 2007 | Motorola Mobility E815
Motorola Mobility E815 Logo
145 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
