I am printing documents with minimum color yet I can only get 128 sheets to my colored ink. The black does not go down just my colored
SOURCE: my printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
SOURCE: color ink cartridges empty, printer wont continue to print
select print black only from the print or page set-up.
SOURCE: Will not print black , HP PSC 1610 All-in-One
Here was the solution. You MUST use HP brand black cartridge. Originally I purchased a #94 Office Max brand black cartridge. After it did not work I took it back and they gave me a second Office Max brand and that did not work either. So I took it back and they sold me an HP brand (I only needed to pay the difference in price so Office Max was good to work with). I installed the HP #94 black cartridge and everything now works.
SOURCE: Printer won't print in black
Here's a link to the HP online support solution for this problem. And this may pertain.
Make sure you have the correct settings in Print Preferences. And perhaps use the online manual available here to check other options related to the ink cartridges and printing problems....
But I have to admit I know of no way to keep the color cartridge from printing, nor from having to buy another cartridge (short of refilling it). I am intrigued by the notion that you can possibly get a grey photo cartridge instead of the tri-color cartridge to print black and white photos and richer blacks...but have never tried this, and don't know for sure if it's an option for your model....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
a.
Press INK.
b.
Press the UP OR DOWN ARROW key to select Test Print.
c.
Press OK.
d.
Use the UP OR DOWN ARROW key to select Print Quality.
e.
Press OK.
f.
Press COLOR START
The
machine will generate the Print Quality Check Sheet.
2.
The LCD will ask "IS QUALITY OK? 1. YES 2.
NO"
a.
Press STOP/EXIT to return to the "Date and Time" display.
3.
Evaluate the Print Quality Check Sheet.
On
the Print Quality Check Sheet each of the four colors is represented by a
slanted square pattern made up of 96 individual blocks. The colors should appear
in the following order from left to right: Black - Yellow - Cyan -
Magenta.
NOTE: Cyan
is the light blue color and magenta is the pinkish color.
a. If
the colors on the Print Quality Check Sheet do not match the sequence listed
above then the ink cartridges are most likely installed in the wrong order.
Continue to STEP 4 to resolve this.
4.
Open the Ink Refill cover.
5.
Open the cartridge covers of the colors that do not appear in the correct
order.
6.
Remove the cartridges and reinstall them in the correct slots. On Brother
Genuine Cartridges the color of the label will match the color of the cartridge
cover.
7.
Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink
supply tubes with the correct color. One or more of the ink cartridges may run
empty during this process. If they do, replace the empty cartridge with a
Brother Genuine Ink Cartridge before continuing the process.
a.
Press MENU - BLACK START - MENU. The LCD will display
Maintenance.
b.
Press 7-6, The LCD will display CLEANING ALL
c.
Press 6, the LCD will display eINIT__P ALL
d.
Press the RIGHT ARROW key until one of the colors that was installed
incorrectly is displayed. i.e. eINIT__P CYAN.
e.
Press the BLACK START Key.
8.
Print another Print Quality Check Sheet
a.
Press INK.
b.
c.
Press OK.
d.
e.
Press OK.
f.
Press COLOR START
9.
The machine will generate another Print Quality Check Sheet.
a. If
all four colors printed correctly the issue is resolved.
b. If
one or more of the colors are still not printing in the correct order repeat
STEPS 4 - 8.
