Question about Endless Summer 233010 Natural Gas Stainless Steel Commercial Patio Heater
Heater will not light pilot consistently - although I did get the pilot to light a few times and got the burner to light once, but the burner stopped after a few seconds. The pilot does stay lit. I presume a thermocouple?
    President:
  • 1,723 Answers
Yes, it's probably bad.
Posted on Jul 02, 2009
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
Heater ignites with a whoosh and blows out the pilot light
Thank you for posting your question here on Fixya.com.
Clear out the spiders or other debris that is blocking one or several gas jets into the burner tubes. After the heater lights the first time, use a mirror to see which burners are not producing a flame to know which jets to clean. At least the one closest to the pilot assembly will be blocked.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
May 31, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
How do I light my Rheem water heater if my peizo ignitor switch isn't working
Remove the burner access cover under the control valve. Press the pilot light button (gas control) and hold it down. At the same time, light the pilot. Continue to hold the lighting button for a few seconds until the thermocouple heats up. Release the button. Twist the gas control knob to the ON position, and the burner should fire up after a few seconds. Replace the access cover. Good luck.
Feb 09, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Hi: I have a atwood-6-gallon heater, the pilot works well but when I try to switch over to the main burner the pilot goes out time after time --- only used once. Thanks in advance Jim
This can be caused by a number of problems.
1. How long has the pilot been lit before you turn it to burner? It needs to warm up the end of the coupler. When you push in on the knob to light the pilot, hold it in for a while after the pilot lights. This allows more gas/hotter pilot flame to warm things up.
2. How fast are you turning it to burner? You need to do it really slow. The gas is under pressure and can blow out the pilot if you do it too quick.
3. Is there a blockage in the tube? Lady bugs, spider webs, etc. can cause a blockage and this problem. It's pretty common. (A long pipe cleaner will clean it out in a few seconds.)
If all of these fail:
4. It it getting too much/too little air? Check the air gap in the end of the tube. (Also called air manifold)
Feb 03, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
Im looking for the pilot light
The pilot light is normally located over the just burner box and will have a small door or removable panel to help get to it. The easiest way to find it it to first locate the gas valve. This will be an aluminum block with a few pipes connected to it. It will also have a knob with Off, On, and Pilot written on it. Once you have found the gas valve, look for two small diameter pipes about 1/4" and 1/8" in diameter. Follow these pipes inside the burner area. It will lead to the pilot assembly. Follow the directions on the heater to start your pilot.
Oct 12, 2009 | Cozy Enclosed Front Console Heater 70,000...
Water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
Aug 30, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Endless Summer 233010 Natural Gas Stainless Steel Commercial Patio Heater Logo
261 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
