Question about Sony Handycam DCR-TRV27 Mini DV Digital Camcorder
Error message; has something to do with insertion of tape. Looks like triangle over straight line. beeps and blinks, will not play. Working when loaned to a "friend", returned in this condition...
Dcr-trv-27 battery display output power indicator shows low after a few minutes when i charget for over 6 hrs.
Posted on Jan 25, 2010
  • 34 Answers
Will it record on a new tape? Will it play a different tape? Have had a similar problem with a different camera. Think it had to do with the record mode / play back. A bit like standard play and long play - are there setting like that you could change?
Posted on Jun 26, 2009
When i put a tape in to watch,or record,the video camera beeps and C:3123 appears i have tried everything
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
I found many people saying that they had this error and "smacked" the camera... and then it started working. This would tell us that it is a mechanical error... so, at your own risk, if the above steps don't work, I would try smacking it a bit, maybe something mechanical is "stuck".
Mar 01, 2011 | Cameras
I have an older (1996) Sony Handycam CCD-TRV211. I am using the player to transfer my old 8mm tapes to my computer. The player will play for about 4 seconds then stop. I get a blinking triangle with a...
How are you powering the camcorder ? Many will not transfer videos if battery powered, since the battery may fail. Try again with the camcorder mains powered, see if that helps. Have you cleaned the heads with a cotton bud and a little IPA ?
Mar 01, 2017 | Cameras
I turn the camera to record and it blinks an icon which resembles ejeciting the tape. It is a triangle over a line. It also blinks "C:31:23" It will not allow me to record. What is it?
You need to try to eject the tape and put it back in the camera. That error means that something has happened with the tape transport and the camera could need a cleaning tape but not necessarily. Try re-inserting the tape. If the error appears again, try a different tape. If the error still appears, run a cleaning tape in the camera on playback for 8-14 seconds (no longer!). Then put a regular tape back in. If you still see the error, there is probably a mechanical problem in the tape transport and the camera will need to be repaired. It's possible it could just need a clean and lube on the mechanical parts, but in any case you will need to take it to a camera shop for an estimate.
Nov 30, 2010 | Sony Handycam DCR-TRV330 Digital Camcorder
I have a Sony PDX-10 and it's giving me two blinking yellow symbols (underlinded triangle and tape with line through it) when I fire it up loaded with a tape. Tried changing with tapes that work fine in...
Looking at PDX 10 User Manual Page 232
Your description -
Under lined Triangle
Cassette Ejection needed
Slow Flashing: The Write protect tab exposed
Fast Flashing: Moisture Condensation
Cassette out of tape
Self diagnosis display function activated
Sounds like the diagnosis function maybe your best shot......
Check displayed error codes in viewfinder on Page 231 of the User Manual or let me know if you dont have copy of them.
Tape Symbol Flashing:
Tape near end
No cassette inserted
The write protect tab exposed.
I think this is basically telling you the loading mechanism has a problem, the viewfinder is displaying an error code indicating the nature of the fault..... IF error Code is : E61:........ or E62........ (dots indicate extra numbers) these MUST be referred to Sony Service Centre.
Hope this may help
Ian 561
Jun 24, 2010 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
When i turn it on it will not play and makes a beeping noise. on the screen it blinks with a signal, triangle with a line underneath
turn off
put in play mode button
turn on
and
wait...
it no response hit menu to see if play mode is locked out
see your manual
Nov 01, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Screen has error message and won't play tape. What is wrong?
This message appears when the loading tape path become misaligned (mechanically unstable). Your camera just need mechanical adjustment from any expert and it will work fine again. Contact any service man for this.
Thanks for using fixya.
Jul 10, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Jan 09, 2009 | Sony Handycam DCR-TRV240E Digital...
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Canon mv700 not loading tape
if you hear the cylinder drum running to fast try take out the connection of the drum at the circuit and back it again...try this in you can open your camera....
Aug 08, 2007 | Canon MV700 Mini DV Digital Camcorder
Sony Handycam DCR-TRV27 Mini DV Digital Camcorder Logo
213 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
