Question about Sanyo EM-W3000W 1000 Watts Microwave Oven
SANYO EM-815FW MICROWAVE OVEN
I want assistance about SANYO Microwave EM815FW. It dosn,t work on auto mode .it has touch button system .Its touch button system not work. time controler not work .
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work,
    leave it unplugged for about 5 minutes. Let us know what you find out.
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs when door open
This is probably a a bad door switch or door switch mount. Chances are only the fan and light are running when you open it, but better safe than sorry. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure but not the only one. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. You can find these files by searching at Yahoo.com (not Google) for this: microwave display safety.txt If you still have a problem, please write back with more detail. Be safe!
Posted on Nov 21, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Sanyo EM-P740w
It looks like you would enter the cooking time then press POWER 1 to 10 times. Once = 100%, twice = 90%, thrice = 80%, and so on, and "PL#" will appear in the display where "#" is the selected power level. On some models, twice = 80% and thrice = 60%, etc. and "80%", or "60%", etc., will appear in the display. Then press START. Did that do it?
Posted on Dec 07, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Sanyo Microwave Oven EM-D9552SN - cutting out
It may be that the magnetron is running a little hotter with a smaller load: Since fewer microwaves are being absorbed, more are being reflected back.
It may be a bad connection on the control board or a bad relay.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
If not, maybe you can keep a microwave-safe container inside with about 1/2 cup of water to "preload" it. Some people do that, especially when making popcorn.
Posted on Nov 28, 2007
  • 833 Answers
SOURCE: sanyo microwave EM-X515G
I'm thinking that the circuit board has a problem. I doubt it will work but disconnect all the connectors on the board...with the power off and reconnect. It may clean off some goo. If not, use your method as long as it will work and then consider a new board.
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sanyo EM S8000-w microwave range quit..fuse?
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
We're happy to help and we appreciate your thoughtful rating of our answer.
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
Manual for sanyo microwave oven EM-S3553S
Here it is
http://eu.sanyo.com/AssetBrowser/Technical%20Database/Instruction%20Manuals/Microwave%20Ovens/EM-S3553.pdf
Mar 13, 2013 | Microwave Ovens
I need to change the lightbulb on my em-s5002w Sanyo Microwave. What screwdriver size & style do I need for lower star-shaped screws
The star-shaped screws are called TORX and range in size from T-1 [small] to T-50[ quite large]. a set of inexpensive bits that fit a driver handle can be found at a hardware or auto supply.
Jan 24, 2013 | Sanyo EM-S5002W Microwave Oven
Need a user manual for a Sanyo Convection and grill model em-d981
Need one too - if anyone has one that is in .pdf format they could send it would be much apreciated
Jun 06, 2010 | Sanyo Microwave Microwave Oven
Buttons are hard to push, always gives me a
Hi, no need to trash this unit. you can repair this and, its quite easy. the touch pad(key pad) is faulty and, you can purchase the replacement pad, via the link provided below. the instruction will be shipped with the part if you order it from the site. you will need to remove the units cover and, the control panel will be exposed. just replace the bad with the new.
Click here to purchase a new Touch key pay.
Jun 18, 2009 | Sanyo EM-N107 600 Watts Microwave Oven
Replace fuse in sanyo em-z2000s microwave onen
try replacing the fuse.there might just be a voltage fluctuation in your locality
Mar 16, 2009 | Sanyo EM-Z2000S Microwave Oven
Sanyo microwave EM-X515G
Dec 15, 2007 | Sanyo EM-S5002W Microwave Oven
Sanyo EM-W3000W 1000 Watts Microwave Oven Logo
87 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
