Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 - Will not turn on
I have a Dell Dimension 5100. This morning the tower would not turn on. I checked to make sure the surge protector was working and the power cord was connected properly. I cannot figure out why it would just not turn on.
    President:
  • 1,383 Answers
Open cpu cabinet.
Reattach ATX power supply connection to motherbord. ATX from SMPS to motherbord.
then check if it still not power ojn then clear cmos.
Pul away your cmos cell for 15 minutes from motherbord then check .
ALso change cmos cell if it is old.
Posted on Jun 26, 2009
I have a dell dimension desktop. It won't turn
open the tower//
check for any loose connection of the cord of Hard drive and power unit//
better option is take out the wires one-by-one and refix it//
if this does not work then probably the SMPS has gone bad and needs to be replaced..SMPS is the power unit which supplies power to all the component.
during all this process please alwaws make sure that when you put ur hand in the tower then the power cord should be out , otherwise you can get power shock.
May 15, 2010 | Dell Dimension E510 PC Desktop
Hello, the green motherboard light on the computer
If there is no loss of functionality then I would say no.
Sep 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell tower desktop Dimension 5100. Tower makes whistling sound.
sounds like it could be a bearing in your hard drive. is this problem constant? If so, I would open up the tower and disconnect the hard drive and then power up the tower again. if the sound goes away--you need to get a new hard drive. If not, you could have some dust bunnies in your cooling fan.
Jun 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Desktop Dimension 5100 is not booting up
please check first your bios settings.. its could be on the boot up settings. you must configure it out correctly..
May 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
No power to Dell demension 5100 desktop
If there is no activity whatsoever when you press the power button on than you have likely blown the internal power supply fuse. This will need a technician to repair.
Apr 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Unable to get front of dell dimension 5100 to check power switch
They say “a picture is worth a thousand words”.
Follow this link: http://support.dell.com/support/edocs/systems/dim5100/en/sm/parts1.htm#wp1371329
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computer wont start and is showing bootmgr missing how can i fix this We had a lightening storm recently. My 5100 was plugged into a surge protector. Every other device connected to the surge protector is...
Its not the surge protector problem.
1. Starting your computer press the F8 function key
2. Select Safe Mode
3. Select the restore point and restore the last updations you had done by selecting the date
4. Wait for a time to get confirmation
5. It will restarts the system.
If the above steps are not worked you need to re-install the OS
Let me know that your problem is solved and rate me as fixya!
Jun 21, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100
buy new power suplly for it ok
Feb 11, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Upgrade
according to this cnet.com (http://reviews.cnet.com/desktops/dell-dimension-5100-pentium/4505-3118_7-31429803.html) the dual core is not an option. I'm not sure if that means that Dell doesn't offer an upgrade, or if it's not possible. First, open your tower and look over the Motherboard for the manufacturer and model. Once you have those, google them and look for the specs of what cpu's are supported by that motherboard. If you can and do decide to upgrade, check with the CPU manufacturer to see how strong of a power supply you need for the more powerful CPU. You're might be ok, but you might need to upgrade the PSU (Power supply) with the processor. From your description, I can't tell what motherboard is in your Dell. That will be the limiting factor. Get the motherboard specs and you'll know what you can do.
Sep 04, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
310 people viewed this question
Alun Cox
