Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
Got an F 02 on control panel. - KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
  • leajones99 Jun 26, 2009
    Thanks! I was afraid of that!
  • 3,230 Answers
It's better if you can provide the model number.
anyway this error code means - "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too.
Good Luck!!
Thanks
Posted on Jun 26, 2009
We want a control panel Part No. 1604 9422 02 Xc2002 for our atlas copco air compressor XAMS 850 CD7. Can you help us on that.
we don't sell parts for anything
contact your atlas copco service center for the parts or get them from e-bay
Sep 20, 2016 | Air Tools & Compressors
Expedition locks. 02 Eddie Bauer.. FUNKY
Check the body control module. All the locks go through it.
Feb 14, 2018 | 2002 Ford Expedition
How do I unlock the control panel on my spa?
Here's a link to a list of ways to unlock the control: http://spapartsshop.blogspot.com/2012/02/spa-control-panel-unlock-codes.html
Those guys should be able to help.
Nov 25, 2012 | Hydro Quip Inc Pool & Spa
F 02 flashing on control panel
F/02..
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Oct 21, 2012 | Kenmore HE3T Washer
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
General repair for a 2002 mercedes c or e class car
general repairs for the 02 c-class are thrust arm bushing and or the thrust arm itself, on the 02 e-class its the lower control arm bushings and the lower ball joints. brakes need replacing about every 12k-15k miles. c-class has a lot of problems with the battery going dead due to a voltage drain from either the seat control modules to the overhead control panel.
Sep 27, 2010 | 2002 Mercedes-Benz C-Class
Folder options in my control panel and in tools menu
hi friend
ur pc has been infated by viros taht y the folder option remove so u have to do this dwonlaod the latest updated antiviors form the intenet downlod it install ur pc scan form it see the link for more info
http://maintainyourpc.blogspot.com/2008/02/registry-editor-disabled-by.html
http://maintainyourpc.blogspot.com/2008/02/task-manager-has-been-disabled-by-your.html
after removing viorus here is link for ur restor ur folder optin link downlod soft & install it
http://www.raymond.cc/blog/archives/2007/06/28/restore-task-manager-regedit-and-folder-options-disabled-by-virus/
Mar 28, 2008 | Microsoft Office Professional 2007 Full...
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
130 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
