Question about Lavazza Espresso Point Capsule Machine
Replacing the float on Lavazza ESPRESSO POINT
    Problem Solver:
  • 10 Answers
You will most likely need to order lavazza part# 87068 (retainer) and Part# 79257 (float)
Posted on Aug 25, 2009
Need a canadian supplier for lavazza espresso point capsules
Lavazza Products may be ordered online in Canada from the following site:
http://www.espressocoffeeitaliano.com/ourproducts.php
Contact Information:
Espresso Coffee Italiano of Canada Ltd.
(authorized distributor of the Lavazza Espresso Point System)
201 Drumlin Circle, Unit #3, Concord, ON
L4K 3E7, Canad
Tel: 905-907-5049
Fax: 905-760-5606
Email: info@espressocoffeeitaliano.com
Dec 13, 2011 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso point not heating up
The electronic control board is defective, it must be repaired or replaced.
To get a dealer address send an email to: f.vitare@lavazza.it. I could help you, but, I live in Canada. Guru
Nov 15, 2011 | Lavazza Espresso Point Capsule Machine
The water reserve light is flashing and the float is broken off. Will this cause the machine to not work and can it be repaired
This will cause the machine not to function because the magnetic sensor is not detecting contact from the float. All you need to do is simply attach the FLOAT ROCKER to the FLOAT RETAINER. The Float Retainer resembles a small thimble with two skinny pieces of plastic sticking out from the side. This allows the Float Rocker to slide onto it through the hole provided on the Float Rocker. This assembly will only work correctly one way so there may be some trial and error. To correctly install the Float Rocker and Float Retainer, have the assembly face the front of the machine. Now, if the Float Retainer (which looks like a thimble) appears to be broken a replacement will be needed. Don't worry, these are inexpensive. Locate a business that sells Espresso Point Matinee's and hopefully they will have parts.
Sep 14, 2011 | Lavazza Espresso Point Capsule Machine
My Lavazza Espresso Point keeps blowing one of the glass fuses, any adsvise?
Typically when this has happened I have found the issue being the plug holder and fuse block. Simply have the Plug Holder and Fuse Block replaced and the issue should be resolved.
Jun 10, 2011 | Lavazza Espresso Point Capsule Machine
Cold espresso
it may be the the back fuses not working or the two thermostat are not working good, or the worst possibility can be the electronic card.
Mar 19, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza point espresso machine
Sounds like you're in need of a new chamber and possibly some thermostats. For service you can call 781-393-2929, we are an authorized Lavazza distributor and repair center.
Jul 23, 2008 | Lavazza Espresso Point Capsule Machine
LAVAZZA ESPRESSO POINT CAPSULE MACHINE WON'T GO ON
There are two ten amp small bus fuses in the back of the machine directly next to the iec power cord. Should you need service you can call 781-393-2929. We are an authorized lavazza distributor and repair center.
Jun 19, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza espresso point
Did you fill it with water? are any of the lights blinking?
Jan 02, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
149 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
