Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
LG Fridge bottom freezer
Freezer works fine, fridge does not cool at all
Been serviced twice with freezing up in freezer.....
We have been very unhappy with this unit.
  • 1 more comment
  • WTG62 Nov 06, 2007
    The freezer is no longer working.
    Only 2 years old....
    I think we will not have it repaired.
  • WTG62 Apr 12, 2008
    Yes, we had the fan replaced in the first year.....we scrapped the damn thing and bought a new refridge...NOT an LG
    Thank you for the posting
  • Anonymous Mar 23, 2014
    Put a thermometer in the fridge and found it fluctuating from 28F - 34F. Doesnt seem to mater where the setting is. Freezer seems fine, its just the fridge. Obviously freezing food is the issue here,thoughts?JD
Have you had the evap fan replaced, if not that sounds like your issue.
Posted on Apr 12, 2008
Kitchen aid bottom freezer fridge. The freezer part is cool but does not freeze.
Maybe lossing gas slowly have your tech confirm this for you.
Jan 14, 2016 | Refrigerators
LG Fridge not cooling refrigerator (freezer is fine, fan is running)
those sensors do fail but if the freezer is not as cold as it should be .then the refrigerator part will also not get proper cooling . TEST the freezer temp .
Sep 25, 2015 | LG Refrigerators
Fridge is not cooling, fridge is working fine
Hello Dan, Is Your Fan in your freezer compartment on ? sometimes the evaporator coils will freeze up not letting the air cool the refrigerator
Dec 25, 2013 | General Electric GFSS6KKXSS Stainless...
I have A LG SXS Fridge. The Freezer is fine the fridge is not cold. I have read that the damper door might be closed. How do I find the damper door?
The damper is between the fridge and freezer section.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
LG LRBN20514ST Bottom Freezer Frig cooling problems
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerator warm, freezer too cold
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | GE Monogram ZICS360NRRH C... Bottom...
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
319 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
