Question about Microsoft Xbox 360 Console
We have a of a red quarter circle. we tried changing cables and it still doesn't work.
  • ksmcgarvey Jun 28, 2009
    It's in the lower right side.
  • 37 Answers
Is it in the lower left or right if its standing up?
Posted on Jun 26, 2009
I have a hk avr 85 and it is in protection mode...red circle around the power button...how can i reset that? I am in Virginia where can i get service?
Try hiting it on the top fairly hard or on the side of it, If that doesn,t work ,It will have to be taken in for (Repair)
Nov 30, 2012 | Audio Players & Recorders
Four red flashing lights are appearing on the power switch
Your xbox does not detect an AV cable. Unplug the cables from both the xbox and the tv. replug them and try again. If this doesn't help, borrow a friend's cables and try it. If that fixes the problem, you can order new cables online and get back to playing. If that doesn't work, you need to contact customer support and send it in for repairs.
Sep 19, 2011 | Video Game Consoles & Games
My toshiba external harddrive usb 3.0 won't work
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps you
Sep 18, 2011 | Toshiba Notebooks Canvio E05a075cau3xw 750...
When I turn on my 2 terabyte LaCie DD3US external hard drive, disk appears to rotate but I get a red light along with the blue, and clicking noises, and the drive's icon doesn't show on my iMac...
If the device doesn't show up in Mac System Profiler at all or as an unknown device:
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If possible, obtain another power cabling to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to another port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test. Try it on a friend's computer and see if it works fine.
If the tests above don't help, it's possible that the drive was either dropped while running, had a hard drive 'head crash' or the circuitry inside the drive is fried.
Hope this helps!
Jun 20, 2011 | Computers & Internet
When I switched on the power button , instantly following which an orange(red) light circling the power button lights and remains as it is at times 3-quarter of the circle and at another instant the full...
your xbox has crashed .Sometimes if you power it down all the way you can reboot, unplug at the console not at the wall beacause there is stored energy in the transformer and you wont get a true power down, good luck
Nov 26, 2010 | Microsoft Xbox 360 Console
I have problems with my Xbox 360 everytime i turn on the 360 there is a red circle. I tryed to fix it but it just won't work anymore how do i fix this Problem
Is there three red lights???? or a complete circle???? Three lights is the red ring of death. Four red lights or a circle is either a bad a/v cable (try a different one) or a bad hard drive....(try taking it off of the side when power is off then turn it on.).
Nov 14, 2010 | Microsoft Xbox 360 Console
A quarter of the circle around the power button is flashing red and it wont let us use any games. How do we fix this?
you have e71 error which means the machine is overheating and needs repair by a propper repair technican
Jun 07, 2010 | Microsoft Xbox 360 Console
Quarter red circle machine wont play
sorry to say but that means you have a hardware failure heres a website that can troubleshoot it http://support.microsoft.com/kb/907536
Sep 07, 2009 | Microsoft Xbox 360 Console
How do I change the passenger headlight bulb on my 2002 Audi A6?
Here you will see the left headlight we are going to take out, but the same procedure can be applied also to the right one (click will open a bigger photo in a new window)
First, remove the cover circled in green (just take it, it is not fixed with screws), then, with a Torx screwdriver, remove the two screws circled in red
Cover removed
Under (yes, almost hidden) the cables circled in red and yellow there are two more Torx screws, you don't need to unscrew them all, only make 2 or 3 rounds
Particular of the screws under the circles in the previous photo (sorry for the bad focus)
Last, we have to remove the power connector. To remove it, pull the little plastic block lever circled in green and then, while holding it, pull out the whole connector (in red). After that the headlight is free, and you can take it out from the chassis
Et voila', headlight removed :) Red circles are for the vertical offset control, don't touch them unless you know what you're doing. Lights are located under the black plastic covers
Mar 08, 2009 | 2002 Audi A6
Microsoft Xbox 360 Console Logo
88 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
