Question about HP Color LaserJet 4730xs MFP Printer
HP 4730 mfp won't print color first print in morning
First job in morning won't print color or color is faded , if they open & close front cover or resend job it works fine. cleaned hvps contacts updated firmware disabled sleep mode & still had problem. swapped transfer belts with good working 4730 & it worked fine for 4 months. problem has just come back. do you think this could be hvps , dc controller or formatter, I was leaning toward hvps.
  • 3 Answers
SOURCE: HP 4700
Try this
Remove all EIO devices and memory Dimm's execpt the firmware dimm.
Start the printer. If the error is gone then place the dimm's / EIO devices one by one.
(Don't forget to switch off the printer.)
If the error is still there then you might have a faulty firmware dimm.
Posted on Dec 29, 2008
  • 285 Answers
SOURCE: HP Color Laserjet: ghost images, both black and color print jobs
Did you try buying a new drum? You should if you have over 25,000 prints on it. You should also try replacing the toner. Please tell me if this helped. Thanks!
Posted on Jan 28, 2009
  • 7 Answers
SOURCE: Color toner is randomly deposited on the back of prints
Loose toner on the belt can be cleaned off with a clean dry rag, This can only be happening if the image is being put down and the paper isn't picking it up. I would look at the transfer belt as causing this, if the belt is not in suspect, the DC controller isn't appying the right bias to clean the belt and drums and would need to be replaced.
Posted on Mar 23, 2009
  • 3 Answers
SOURCE: HP Color Laserjet 2600n Color Alignment
I own a HP 2600n and I had the same problem the way I fixed it was hold both arrow buttons in the turned off the power for 10 seconds while holding the buttons in then turned it back on then released after 3seconds the reset my defaults this cured my problems
Posted on Nov 12, 2009
  • 313 Answers
SOURCE: HP 4730 MFP prints all colors correctly except for
you have to make calibration
Posted on Mar 17, 2010
HP Color Laserjet 4730 MFP scanner not initializing
open the scanner's glass cover ,,, there is a white sensor on the backside of the glass ,,, clean it with a little wet fabric ,,, then change the scanner unit's place to be exactly under the sensor ,,, close the cover ,,, turn on the power ,,, and give me a good rate ,,, :)
Sep 22, 2013 | Office Equipment & Supplies
My computer is not communicating with my printer
Try reinstalling the printer driver.
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Mar 27, 2013 | HP LaserJet 4730 MFP Printer
Hp 4730 fuser reset
Anyone with information on how to reset the Fuser page count without chanigng the fuser on HP 4730 MFP? The fuser in the unit is in very good condition and replacements are not cheap. Any help would be much appreciated.
Mar 12, 2012 | HP LaserJet 4730 MFP Printer
HP Color Laserjet CM4730 Scanner Not Initializing
I had an issue similar to this and it was fixed by replacing the memory dimm on the bottom of the formatter.
Nov 17, 2011 | HP LaserJet 4730 MFP Printer
How do i scan images using the hp 4730 mfp
check under general reference (link below). it should mention how to fax, e:mail and copy. if you copy to file / pc that should work as the scanner.
otherwise make sure the "scanner" facility is installed as some MFP's do not come with all facilities installed. (and therefore may not give the option on the screen.)
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&prodClassId=-1&contentType=SupportManual&prodTypeId=18972&prodSeriesId=468688
Jul 21, 2010 | HP LaserJet 4730 MFP Printer
I have no disk for a HP color lasrjet 4730 mfp and can't install on my laptop
Check out this link. You made need to copy and paste in browser.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=468689&taskId=135&prodTypeId=18972&prodSeriesId=468688&lang=en&cc=us&submit=Go%20%BB
Jul 06, 2010 | HP Color LaserJet 4730xs MFP Printer
When sending print jobs to the HP MFP 4730 device keep processing job and data led keep blinking with no printing
this problem comes due to formatter card it is faulty replacur problem will be resolvee them it will work ...........
Jun 17, 2010 | HP LaserJet 4730 MFP Printer
Incoming faxes on the laserjet 4730 mfp look like bar-codes. Other print jobs are OK
Unexpected image like barcode as shown below can occur when using the automatic document feeder (ADF). You are using the ADF for incoming faxes. So the problem occurs.
If the copy does not look at all like the original document, make sure that no media is on the flatbed glass from a previous copy job.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 26, 2010 | HP LaserJet 4730 MFP Printer
HP Color LaserJet 4730xs MFP Printer Logo
212 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
