Scotts Company Scott'S& Lawn Pro Spreader 3 Pack Logo
A
Anonymous Posted on Jun 13, 2014
What setting for handy green II for grub control?
tip
When a Windows install kills your dual boot to Linux
Distro installers are pretty good at identifying an existing Windows installation and setting up dual booting, but should you have to reinstall a spyware-riddled Windows install you'll find that your machine boots straight into Windows and that your Linux installation is gone!
Don't panic: all Windows has done is overwrite the Grub bootloader with its own equivalent, removing your boot menu. All your data is still there - you just need to reload the bootloader configuration into the disk's master boot record (MBR). You'll need to boot from a Live CD to do this, this, then open a terminal and run
sudo grub-install /dev/sda
This assumes you have everything installed on the first (or only) hard drive. Grub-install will usually make a good job of detecting a Grub installation and set things back to rights. If it doesn't, you'll have to do it manually, which is a lot easier than it sounds. Run sudo grub to enter the Grub shell. then run
find /boot/grub/stage1
...to determine which partition holds the Grub files. If Windows is on the first partition Grub is likely to be on the second, in which case this command will return something like (hd0,1). Now set Grub up with
root (hd0,1)
setup (hd0)
quit
The first command identifies the boot partition, the second writes the bootloader to the MBR and then you leave the Grub shell. Grub is only concerned with the location of /boot, so if you have a separate /boot partition, omit the /boot part from the find command.
on Mar 26, 2010 • Computers & Internet
1helpful
Crank handle parts
www.scotts.com/smg/.../index.jsp?..
1helpful
2answers
Computer wont boot, recovery disk doesn't work after reinstalling it says an error has occurred.
There are two ways, choose which is suitable for you: 1) If you deleted a Linux partition and want to get rid of GRUB: - Insert your Windows CD. - In your BIOS settings, select boot from CD/DVD. - After the welcoming screen, type R (to enter the Recovery mode). - At the console (command-prompt/terminal) type: fixmbr - Everything should run fine after that. 2) If you installed Linux and have a problem with GRUB: - Insert your Linux distro CD. - In your BIOS settings, select boot from CD/DVD. - Enter the Live desktop and open a terminal. - Type: sudo grub -Type: find /boot/grub/stage1 (You might receive more than one location. Select the one you want to install GRUB onto) - Type: root (hd?,?) (Where "?" is the location you want to install GRUB) - Type: setup (hd0) (This is to install GRUB onto mbr) - Type: quit (To exit grub) - Reboot and everything should be fine.
St. Gabriel grub control - Purchased 20 lb. bag
In terms of grubworm control, 'milky spore' products are bacterium meant to create a long-term soil-borne epidemics amoung grubs in the soil. Milky spore very likely will not kill existing populations that're eating at turf roots & thus, doing damage.
But milky spore is an environmentally-conscious product, and certainly a wise long-term investment for those who've put a lot of investment in their lawns.
In leiu of milky spore, I recommend any product containing Dylox for active infestations.
Milky spore may be applied in that same season in an attempt to start that longer-term, human & pet-safe grumworm contagion.
It is perfectly normal to see small numbers of grubs in the soil, in both turf & landscape. In small numbers, grubs are generally harmless. The concern mounts when their numbers are higher.
This is how to check for actively feeding grubs:
In turf areas that are turning brown, get on your hands & knees and take the turf into both hands, and pull.
If the turf readily comes up as if it's carpet, you'll likely see the "lawn shrimp" (haha) underneath.
In a 12" x 12" section, if you see more than 2 grubs, it's time to take action.
Answers:
1) No. After applying Dylox & watering in per instructions, wait approx 1 week to 10 days, then peel back some of those sod areas again.
If it's working, the grubs will have slowly turned from an ugly grey to a light beige, and shrunken somewhat.
2) No. Moisture on grass at time of application doesn't matter. What matters is that you irrigate thoroughly AFTER application.
3) Actually, it is to your advantage if adjacent soil areas aren't treated with milky spore. If ALL grubs are killed, then there will be no carriers to continue the bacterial contagion. Even if your neighbors are grub-free, keep in mind that Japanese, June beetles, masked chafer, etc will drop eggs into the turf season after season. (There's nothing you can do about that.) And these eggs will eventually metamophecize into grubs. If you have milky spore in the soil, they shouldn't mature to the point to which they'll feed.
4) Products containing Dylox are labelled to kill grubs of all species of beetle. At about the time you're seeing June beetles swarming your back porch light, they're likely laying eggs in the turf. Most species of grubworm potentially can do damage 2X year:
JUST before the adults emerge, and about a month to six weeks after the maximum height of adult population.
Here in s. Ohio, late September thru first ground freeze tends to be historically the worst peroid for grubs. But some years, mid to late spring damage can be found, too.
No grub loader
You havn't mentioned whether Ubantu inquired about the grub settings during its installation or not. If Windows doesn't have the boot loader than you can manually check it by looking at the boot flag set at a particular partition. This can be done by using an open source media GParted live cd, which can be used by booting from your CD Drive and then you can check and also set the boot flags at a particular partition. You can find it here: LiveCD-Download-8864.html">http://linux.softpedia.com/progDownload/GParted-LiveCD-Download-8864.html After burning, boot from it and in the GParted menu set the boot flag for the Ubantu partition, then you can use your your Ubantu, only if installed correctly, may be you can't use windows at that time, then remove the boot flag and windows will be back. Try installing Ubantu again and check the settings for grub bootloader.
3helpful
Pc linux OS reboot loop
It might be cause by The MBR was messed up by a bad grub install. You can try to fix the grub.
If you want to try reinstalling grub, boot from the live CD, log in as root, open a Konsole window, and at the prompt, ([root@localhost ~]#) type;
[root@localhost ~]# grub <Enter>
GNU GRUB version 0.97 (640K lower / 3072K upper memory) <-- This is the output from grub after <Enter>
[ Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists the possible
completions of a device/filename. ]
grub> <-- The grub prompt.
From the grub prompt type;
grub> find /boot/grub/stage2 <Enter>
(hd0,0)
(hd0,4)
(hd0,5)
(hd0,9)
(hd0,11) <-- You'll only have one, use it
(hd1,0)
(hd1,2)
(hd1,4)
grub> root (hd0,5) <Enter> <-- Use what showed up above for yours
Filesystem type is ext2fs, partition type 0x83 <-- Grub reports both ext2 and ext3 as ext2. Don't worry about it.
grub> setup (hd0) <Enter> <-- That is a zero (hd0), not a letter
Checking if "/boot/grub/stage1" exists... yes
Checking if "/boot/grub/stage2" exists... yes
Checking if "/boot/grub/e2fs_stage1_5" exists... yes
Running "embed /boot/grub/e2fs_stage1_5 (hd0)"... 15 sectors are embedded.
succeeded
Running "install /boot/grub/stage1 (hd0) (hd0)1+15 p (hd0,5)/boot/grub/stage2 /boot/grub/menu.lst"... succeeded
Done.
grub> quit <Enter>
Your done; grub is reinstalled
P.S.: If this information was helpful, please rate this solution.
Top Scotts Company Garden Experts
Jay Finke
Jay Finke
john h
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
