Question about ASUS MyPal A626
'unknown publisher' cant install any program it says "unknown publisher" i click "yes" it says installation is unsuccessful
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
There are 2 things;
either you are installing a program that is not for your device or,
the program that you are trying to install has errors.
make sure that the program is not corrupted or is the right one for your device.
Posted on Jun 26, 2009
Cant start video. Try closing other programs that might be using your webcam
1st You download Webcam Driver.
webcam Installer After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Other Companies Camera Drivers for Windows XP Vista Windows 7
Sep 18, 2013 | A4tech Computers & Internet
Unable to use Micrografx Picture Publisher 10.0 with Win 7
Make sure that Micrografx Picture Publisher 10 pro installs into the X66 Program files folder.By default it will always install into the 64 bit program file if you have a 64bit installed.
If you have the 32 bit Windows 7 installed then right click with your mouse on the program before opening it up and select compatibility mode.Select XP SP3 compatibility mode.This works fine on my Windows 7 32bit. Use the first paragraph method if you have the 64bit Windows 7.
Regards Brian
Feb 14, 2011 | Micrografx Picture Publisher 10
"product installation unsuccessful, please
check to see if fire wall is blocking it.
Feb 02, 2011 | Computers & Internet
I just got my creating keepsake scrapbook designer v.3 i installed it, still have the version 1.5
hi, aejedennis:
You could try uninstalling version 1.5. click start, and click on "control panel" on the start menu. When the control panel window opens, click on "add/remove programs" This will open a window with a list of programs installed on your computer. Find Encore Creating Keepsakes Scrapbook on the list. There may be listings for both versions. Click on the listing for v1.5, and it will expand. The expanded listing should include a button you can click on labeled "remove" or "Uninstal". Click on it and when a window opens to ask if you really want to remove the program, click on yes. It might ask you if you want to keep your saved files, click yes to that if you mind losing stuff you have saved using the program. You might have to install v3 again.
Jan 17, 2011 | Encore Creating Keepsakes Scrapbook...
How do i download the driver for A4tech PK-5 webcam? i cant download it and cant install. i have the winzip program in my pc.
Sep 14, 2010 | A4tech PK5
I have Micrographx Picture pubisher 8 and just changed to new PC Windows 7. Now I am being told that Win7 is not compatible! Can you help please? Regards Peter
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Dec 05, 2009 | Micrografx Picture Publisher 8.0 for PC
Who can help i cant install what i want
that depends on what you want to instal if your system can run the program you need check the requierments,or isf you cant instal because youe program is blocked ,or your antivirus is not letting you to instal bad programs
Dec 02, 2009 | Computers & Internet
It doesn't work with vista
If your problem is installing the program, try to get a compatible installation package.
If it installs properly but does not run on vista:
  1. Go to the programs Shortcut right click on it and click properties
  2. Click on the compatibility tab and select the OS you used to run on. Further you can select other features that match your program.
  3. Check on Run this program as an administrator.
  4. Click Ok and test your program's different functions. Check to see if every of its features are working right. If they happen to malfunction better get a compatible version.
Nov 22, 2009 | Cakewalk Guitar Tracks Pro 3 for PC
Guys i have a problem on activating the photoshop cs3
What error message are you getting when you attempt to install?
Were you installing the program with no other applications running in the background. Sometimes it's necessary to disconnect from the internet and disable your antivirus/antispyware programs to have a successful installation.
If that fails, you might find some help in the Adobe forums at http://www.adobeforums.com/cgi-bin/webx/.3bbf2764/
Mar 26, 2009 | Adobe Computers & Internet
ASUS MyPal A626 Logo
131 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
