Question about Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only
Water filter leak
I have a brand new 15X48 above ground intex pool. The water filter leaks from underneath the filter. Any solution?
  • 640 Answers
If the water is leaking, it sounds like you have a connection problem or a hair line fracture in your pool filter. Check all of your connections for loose ones and you should be able to repair the leak.
Posted on Sep 08, 2010
Filter assembly Intex 15X48
The lower hole is for suction and the higher hole is for return.
The Pool Tech
Jul 07, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
How much time for a 15x48 metel pool
it varies from day to day depending on many factors like sun,heat, number of bathers and so on look at the manual and go from there.
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
Jun 23, 2010 | Intex Automatic Salt Water System for ...
Very weak suction on inlet side. Water is green.
unscrew the top valve on the filter carteidge and let the air bleed out
clean filter every day and run it 24/7
Intex pumps can not filter good enough
Jun 09, 2010 | Intex Automatic Salt Water System for ...
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
How do you fix a leak to a 15x48 swimming pool without emptying all the water? it's a small leak on a seam near the ground.pool has been up a week & no leak, until tonight?
They make underwater patch kits that are very simple to use. You cut a patch and apply glue, fold the patch in half with the glue faceing in. take it to the leak and slowley unfold against the hole. smooth out and make sure edges are sealed down. Keep pressure on the patch as instructed on package. Then let cure. Good luck.
May 28, 2010 | Intex Ultra Metal Frame Pool w/ Upgraded...
Brand new filter pump leaking
If it is brand new and leaking, it sounds like your pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Jul 16, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
I have a intex 15'x 48" pool and a8110 salt water chlorinator. Iwould like toknow what type and how much salt I need? It's my first pool. Any set up advice would be greatly appreciated. Thanks O.G/
beleive it or not all pools are not created equal
you can have 2 different brand pools the same size and they will have different water capacity
in your case since you did not tell what model pool we will go the average route
15x48 is an average of about 4000gl
that translates to about 100 pounds of salt
most important is to get a salt test kit and a chlorine/ph test kit both for about 10 bucks each
start with 75 pounds salt throwing it right in the pool then pushing it around to help dissolve it like with a brush
you want 98% pure pool salt, not iodized salt best to get this from a pool store 40lbs for 8-10 dollars
remember not to let them sell you thiungs you do not need or give bad advice
once salt is in and partially disolved turn on filter only for 24 hours
now check salt level with kit
it is imparitive to have your salt level at as close to 3000ppm as you can
you can be as high as 4000ppm but remeber the higher it is the more salt taste you will have any lower than 2500 then it is hard to generate chlorine when needed
try to find some of my other posts dealing with cloudy water and green water and you will read more info on filtering which is a major factor
If you have more questions I am at shhhucantcme2@yahoo.com
Jul 13, 2009 | Intex Automatic Salt Water System for ...
Intex 2500 Gal Easy Set Swimming Pool Water Filter Replacement Pump only Logo
765 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
