Question about Canon PowerShot S2 IS Digital Camera
Viewer turns off (black) when folded back against the camera.
LCD viewer works fine when opened, tilted towards the lens and all the way back until it is pressed and folded back into the camera body. When it is folded back and pressed back into the camera it will not display anything during picture taking and review mode.
    Sergeant:
  • 246 Answers
When the big LCD is black the view finder will turn on, right?
You need to replace a new hinge unit. Here is similar solution
How to fix an intermittent display LCD on Canon PowerShot S5IS
Posted on Jun 26, 2009
The LCD monitor of my Kodak DX7630 camera has turned black. It still works on "review" mode and "menu" mode, but pictures taken are also black. The flash works, everything works, unless...
hi your unit has shutter unit defective in lens unit assemble. you can bring to your local repair shop would charge around $45 to 95 depend on what they really want to charge. Thanks and best regard!
May 27, 2011 | Kodak EasyShare DX7630 Digital Camera
I CANT VIEW IN THE VIEWER WHEN IN THE CAMERA MODE. IT WORKS FINE IN THE VIDEO MODE.IT WILL TAKE PICS IN THE CAM MODE BUT NO SCREEN.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 23, 2010 | Canon PowerShot SD600 Digital Camera
The viewer is black.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Mar 29, 2010 | Canon PowerShot S2 IS Digital Camera
D80-viewer and display stay black, the flash
If your camera got moisture inside and you turned it on before it had a chance to completely dry (usually takes several days) you may have caused a short circuit.
Dec 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
My cannon power shot sd600 viewer doesnt turn on
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. Try pressing this button one more time to see if it turns back on.
Oct 13, 2009 | Canon PowerShot SD600 Digital Camera
Camera lens damaged, have a dark shade on left edge of viewer
If you are able to take photos then I suggest you make a few to figure out if they are also dark like the viewer edge. If they are OK, enjoy the camera while it lasts and perhaps you can adapt to not having a clear view to the edge. I recommend against spending the money to repair this camera as it will likely exceed the cost of replacing the camera.
Oct 08, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Sony Cybershot DSC-W100 LCD viewer
do you guys have a grainy display, that makes it look like there are less color variations?
for example, if you take a picture of something that varies in color from one side of it to the other, with an infinite variation in one color to the next; do the colors separate into grainy spotches, as if it lost some color display capabilities? mine did this, if i took a picture of something that had different hues of one color, they would all flow together into one splotch, and upload fine.
so i sent it in and they said they "reconnected the lens-flex" among other routine things. problem fixed.
but then i sent it in again and they said they did the same thing, but the problem this time around was my capture-mode dial was glitching, the display was FINE. sadly they didn't do jack to fix the dial it and it still screws up. it will switch back and forth from adjacent modes without me turning it.
i'm happy with this camera but its a pain sometimes. if you guys have warranties send your units in ASAP to get it fixed for freeeeeee.
best of luck, i can't suggest anything beyond that.
Oct 07, 2007 | Sony Cyber-shot DSC-W100 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
177 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
