Question about Buck ione Scorpius-R31 Keyboard, Mouse, Touchpad
I have a ione scorpius r-32 usb keyboard that is freezing up on a mac mini V10.3.9 when using challenger software that was created for OS 9. Trying to find if a driver could be install to remedy this issue.
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Jun 06, 2015 | Apple Mac Mini Desktop
How do you "print screen"?
I don't think that this keyboard has that key built in.
Have a look at Gadwin PrintScreen for capturing screens or active windows (and other features). The default hot key for this program is "print screen" but can be redefined.
You could also use the on screen keyboard.
Windows XP comes with a built in on screen keyboard. Basically a graphic of a keyboard comes up and acts like your keyboard, you can use your mouse to hunt and peck around. What uses does this have and what did I use it for? Well, it's good for people with disabilities, where it would be easier to use a mouse than trying to type or it's great to use when your keyboard goes loco on you. Yes, we've all had our keyboard go nuts. Here is how you launch it:
- Click "Start" button - Click on "RUN" - Enter\type "OSK" (without quotes)
The keyboard comes on
You can also create a shortcut to the "On-Screen Keyboard", because if your keyboard should go out on you, it would be handy to have it. All you do to create the shortcut is to:
- Right click on the desktop - Click the new shortcut button - Enter\type OSK, click next twice, and there you have it.
Mar 03, 2011 | Mini iOne Scorpius K3 Slim compact mini...
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
I have a keyboard model Ione Scorpius-35 with built-in trackball...how do I remove the trackball to clean the contacts? Other trackballs had a ring that you could twist with a pen-point and then remove the...
Afternoon. I read that this keyboard does not have any access to the trackball directly. I guess when cleaning time comes, the whole thing will have to be taken apart.
I am considering the purchase of this keyboard; would you recommend it? I am looking for a keyboard with mechanical keys and a built in trackball.
Sep 04, 2010 | Qtronix iOne Scorpius 35 PU/NET Keyboard
IOne Scorpius N4 my laptop does not recognized it , why is that
download drivers for that, it may have complications with your os
Feb 15, 2010 | Aashima iOne Scorpius N4 19 keys keypad +...
Scorpius K3NT USB Keyboard prevents resume after standby in Win2K
When entering standby, the usb ports go to sleep. Most motherboards allow you to tell the bios that you are using a usb keyboard. That should solve the problem. I keep an old ps2 keyboard plugged in and on the floor as a 'just in case'.
Jul 24, 2009 | Mini iOne / Qtronix Scorpius K3NT PS/2...
Kensington wireless mouse doesn't work on Mac laptop.
Kensington wireless mouse is compatible with this system:
PC-Windows® 98, Me, 2000, or XP with USB port
USB Macintosh® with OS 10.1.5 or later
USB Macintosh® with OS 8 and 9 device will only function as a 1-button mouse
If you buy this item you have a disk utility on it and provide the software to run on the system. If not you can download it at this site: http://us.kensington.com/html/4398.html
Jul 08, 2009 | Kensington PocketMouse 72214
Mac Mini Keeps ejecting Only OS X disk, how to install OS X
I had the same problem, but with Windows and Ubuntu I had to make two partitions. I can't remember exactly how I did it but I had to have reference to Ubuntu in each partitions. I hope this helps. mysleuth
https://help.ubuntu.com/community/YabootConfigurationForMacintoshPowerPCsDualBoot
Mar 10, 2009 | Apple Mac Mini Desktop
Install macally icekey keyboard to windows?
It is only for Mac, there are drivers available from the site, all OS and OSX.
Driver - Macally Peripherals
www.macally.com/driver
Keyboard & Mouse · Bluetooth & Wireless · Webcam · Hub & Adapters ... usb. IceCam. IceCam Driver for OS X 10.4 to 10.5 ( updated on 2/16/2008); IceCam ... ICEKey installer for PowerPC and Intel-based Mac OS 10.4 to 10.6(32-bit system only) ... USB 3.0 to Gigabit Ethernet driver for Windows XP/Vista/7/8 (9/10/2013).
Amazon.com: Customer Reviews: Macally USB Slim Keyboard - ICEKEY
https://www.amazon.com/Macally-USB-Slim-Keyboard-ICEKEY/.../B00006HYP6 ... and review ratings for Macally USB Slim Keyboard - ICEKEY at Amazon.com. ... F9 for me shows application windows, F10 isolates the window and F11 ... Macally USB Slim Keyboard ICEKEY Google Search
Mar 13, 2017 | Macally iceKEY Keyboard
Buck ione Scorpius-R31 Keyboard, Mouse, Touchpad Logo
70 people viewed this question
Top Buck Computers & Internet Experts
David Payne
David Payne
Are you a Buck Computer and Internet Expert? Answer questions, earn points and help others
