Samsung TXM3297HF 32" TV
Problem for Samsung TXM3297HF 32" TV
Where is the lamp door cover located
By clloyd995 on Jun 26, 2009
I have a Samsung 36inch tv model number TXM3297HF it has shut off by itself a couple of times, I have read on the net that it could be caused by the auto shut off and something about a lamp door cover,can someone tell me where the lamp door cover is located on my tv.
Best Solution
posted on Jun 26, 2009
Very Helpful)
gullipudstvs
Rank: Guru  Samsung Televisions & Videos  Expert
Rating: 90%, 179 votes
Hi, there is no lamp door and it doesnt have a lamp neither since your tv is a CRT (Cathodic Ray Tube), only DLP's and LCD Projection TV's, For this issue you will really need to consult it with a Repair Center, CRT's are very frindly to fix, and it could be a issue on a small component if it is it will be very cheap to fix.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung TXM3297HF 32" TV
Questions and Unsolved Problems for Samsung TXM3297HF 32" TV
Do you recommend Samsung TXM3297HF 32" TV?
Answer
Answer
Samsung AA26-00069A (FUJ-29002C) has two High Voltage connections. What goes where?
Answer
I have a 42 in Samsung flat screen and the secondary fan is not working. Where is the 2nd dary fan... (More)
Answer
I am unable to retune the freeview channels on my 32" crt samsung tv which means i can't add... (More)
Answer
The tv will play for about 30 mins. and then cuts off. Let the tv sit for an hour or more and it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
