LG 50PA4500 50" 4500 Series Plasma HDTV Logo
A
Anonymous Posted on Jun 13, 2014
My Samsung pn51d430a3d not showing picture
The volume works fine but I get no picture, if he screen is damaged I'd like to know where I can get another screen for a reasonable price?
  • Ian Sawyer Sep 20, 2019
    I'm fixing another one, all plasmas are almost identical.... 60pa6500 this time.
Ian Sawyer
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 16, 2014
Ian Sawyer
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
262
Points
Those screens are worth more than double the price of the whole tv NEW.
Samsung TV Flickering Issue Fix?
I'd look at a bad panel, the defective panel damaged your main, replacing that got it working somewhat but if it's on very long I'm guessing you will damage the main board you replaced. Try unhooking the ribbon connectors one at a time and see if half the picture works ok, if so you definately have a bad panel
How do i fix volume problem , i have samsung 46 inch lcd , picture working fine but no sound?
Hi is your television running through a foxtel box or something else that has volume control, If so you might have one or the other turned all the way down, turn both volumes up and control every thing through one remote control.....
Unable to type characters and numbers
my keyboard xp50 roland when i started the keyboard screen showing user memory damage please help me
Samsung 46 inch lcd no picture only sound
Could be backlight or the Invertor. While the sound is operating shine a flashlight into the screen and see if you can see the picture or not then let me know and I will assist you. But I will also need the model number of the set.
5helpful
2answers
Phone got wet and is now showing "DEMSBL BOOT Loader for MSM6288"
What you are seeing is the mode used to flash your phone. Why it is showing up IDK. You can get to this screen while holding down the volume down button on your phone while turning your phone on. Quite possible something is replicating this volume down key. Maybe play with your volume button and try to turn your phone on or hold the volume up when you turn your phone on and see if you can get by this.
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Screen problems
this means yuor LCD has been damage, go to your cellphone service center to replaced it. putting your cellphone in your pants pocket may damage LCD.
2helpful
2answers
Black screen
whats up with blackscreen?
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
