Question about Hayward Navigator Pool Cleaner
Our Navigator goes around in circles and when it gets to the wall it simply stops. Everything on the outside seems to be okay and not very worn. Is this a gear problem or could something be stuck inside?
    Problem Solver:
  • 7 Answers
Internally, there is a part called the A-frame that has two wheels with ball bearings. There is one on each side and it is what causes the feet to move. Sometimes these wear out and the bearings fall out. This can cause one side to have more movement that the other thus walking in circles. See exploded parts view http://www.h2opoolproducts.com/product_info.php?products_id=48
Posted on Jul 05, 2009
    Problem Solver:
  • 6 Answers
There are two components to the steering mechanism. The uppermost is the motor which rotates to body against the hose and the lower is the steering program. The program controller acts on the motor to vary the speed and direction of rotation. Your problem may be caused by the program controller. You can remove the walker assembly and the bumper to be able to remove the cover from the controller under a round red irregular disc. Disassemble -note where ther parts go - and clean thoroughly. Check that all parts rotate freely as you reassemble. This is a bit involved and my best advice is to take it to a pool store expert.
My Navigator Pro does not go up the pool wall any more. I have checked for air bubles in the hose, all Okay
Make sure that the shoes and wings are not worn on your automatic pool cleaner. Replace them if necessary. Make sure that there is not improper water flow. Clear any blockages in the throat. Make sure that your hose is not too short. Check for proper tension in the cleaner's rear flap.
Feb 05, 2011 | Hayward Navigator Pool Cleaner
My Hayward pool cleaner turns to the left in a circle until it stops moving
There are several things that could be causing this problem with these pool cleaners. First, check your water flow valve. Improper water flow to the cleaner (too little or too much) could cause this problem of going in circles. It could also be a partially blocked throat, worn shoes, or worn flaps.
Aug 17, 2010 | Hayward Navigator Pool Cleaner
Navigator goes in circles
When this problem occurs with these automatic pool cleaners, it is usually an issue with the house having a kink or blockage. I would check that first. If you have, make sure that the wings and shoes are not worn. Make sure the water pressure is not too high. Check the rear screen to make sure that it is clean and not blocked. Check to see that the cone gear is free of obstructions. It might also be the gear box that needs to be replaced.
Jul 25, 2010 | Hayward Navigator Pool Cleaner
My pool vacuum just goes in circles and my other one same make is getting stuck on the pool walls
With these automatic pool cleaners, if they are going in circles, it could be one of a few problems. First, your water flow might be functioning incorrectly. Check the water flow gauge and make sure that is coming out evenly. Adjust if necessary. Also, make sure that you do not have a worn shoe or wing on one side of the cleaner. Also, make sure the navigator throat is not obstructed on one side. The same problems could be preventing it from climbing, but for that problem, you will also want to check that the hose is not too short and that the tension in the rear flap is correct.
Jul 09, 2010 | Hayward Navigator Pool Cleaner
Describe yourIn ground, 18k gallon plaster pool.
sounds like you have some bad bearings on either the turbine or "a" frames. this will cause the navigator to go in circles and coil the hose. also check the tightness of the left and right pods. you can pop off the white cap and tighten the screw with a 1/4" nut driver.
you can buy a turbine kit with "a" frames, that should get it back to "new" condition.
hope this helps...
Aug 10, 2009 | Hayward SAND FILTER, PRO SERIES
Navigator only goes to steps and sides of pool
This could be from not enough hose or your pool returns are aimed in a way that creates a current in the pool that drives the cleaner into the steps and won't let it out. Change the angle of these first then ck the hoses.
Jun 28, 2009 | Hayward Navigator Pool Cleaner
2000 Lincoln navigator air suspension
The air chambers are worn out and this has caused a heavy load on the compressor, causing IT to become loud. The relay could be oxidized from excessive runtime...accordianman
Dec 15, 2008 | 2004 Lincoln Navigator
Scooba circles and only goes backwards.
try cleaning the cliff sensors under bumper
Dec 13, 2008 | iRobot 5800 Scooba Vacuum
Hayward pool vacuum cleaner problem
With this vacuum, start from the simplest possible problem and then work your way through. Process of elimination. Flip it over and see if the feet are all the in good shape. Also look to be sure that the springs that are below each of the feet are actually connected. Where they connect, the tabs break off and then the spring doesn't snap and that side of the vacuum will drag or go in a circle or not move at all. If that look s okay, you need to check the bearings to be sure they're okay. If one side goes you'll experience the same problems you've described. If they are tight, no bearings falling out then check the pods. That's the long sections where the feet and wings attach to the vacuum. As a general rule if you replace the pods, you should replace the Aframe as well. Not difficult and the parts will run $110-$125 for an entire bottom kit which includes everything that has been described above.
Oct 05, 2008 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
1,145 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
