Question about Canon PIXMA MP160 All-In-One InkJet Printer
Flashing E and the number 5 - Canon PIXMA MP160 All-In-One InkJet Printer
    President:
  • 2,306 Answers
E 5 says that the ink color ink cartridge is defective or not compatible with your machine. You can try wiping the contacts on the cartridge, but you probably need a new ink.
Posted on Jun 26, 2009
    Problem Solver:
  • 24 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq2
Posted on Sep 05, 2009
Flashing error codes
Carefully count the number of flashes that occur in each sequence; for instance, it will flash 5 times, pause, and flash 5 times again. Go through several sequences to make sure your count is correct as it will always be the same number of flashes. Here is the owners manual, go to page 37 to find the flash code page and look up your number. Then post that back here for more information on how to proceed.
Jan 10, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
What is service engine light code 12 mean
READING CODES USING MIL (CHECK ENGINE) LAMP
Be advised that the MIL or CHECK ENGINE light can only perform a limited number of functions and it is a good idea to have the system checked with a scan tool to double check the circuit function.
  1. Within a period of 5 seconds, cycle the ignition key ON - OFF - ON - OFF - ON .
  2. Count the number of times the MIL (check engine lamp) on the instrument panel flashes on and off.
The number of flashes represents the trouble code. There is a short pause between the flashes representing the 1st and 2nd digits of the code. Longer pauses are used to separate individual 2-digit trouble codes.
An example of a flashed DTC is as follows:
Lamp flashes 4 times, pauses, then flashes 6 more times. This denotes a DTC number 46. Lamp flashes 5 times, pauses, then flashes 5 more times. This indicates a DTC number 55. DTC 55 will always be the last code to be displayed.
Fig. Fig. 2: Diagnostic trouble code chart (1 of 2)-1995-97 engines
Fig. Fig. 3: Diagnostic trouble code chart (2 of 2)-1995-97 2.0L engines
Jul 26, 2012 | 1995 Dodge Neon
We have a 1990 plymouth voyager which is producing white smoke and a liquid that smells like gas from the exhaust pipe. The car shakes slightly,and makes a a guggling sound when idle. We made it home...
You should be able to cycle key to on (not start just on) then off, then on, then off, then on, and leave it on. Check engine light should flash codes. There will be a number of flashes, then a small pause, then more flashes.That will be the 2 digit number, for example: flash, flash, pause, flash, flash would be code 22. 3 flashes, pause, then 5 flashes, would be code 35. When you get 5 flashes, pause, then 5 more, that is code 55 which means end of message, or codes. Have a pen ready and write them down and get back to us with those numbers for faster assistance. If that doesn't work, see if you can get to one of the big autoparts stores like Autozone, or Pep Boys, and they will scan it for free to pinpoint problem before spending money on guessing.
Nov 17, 2010 | 1990 Plymouth Voyager
Ford 2001 F150 pickup truck beeps approx 5-6 times every 5 minutes. Think i has to do with the airbag.
Yes you are correct, it is an airbag problem./
The Airbag indicator lamp is burnt out, and a flash code is waiting.
Radio shack ( or similar ) should still have the replacement bulb for it.
Once you put it back in, the airbag lamp will flash a code that is a number, t ( ie flash 3 times ) then another number ( ie flash 5 times ). You will need that code for the next step in the diagnoses. Don't be alarmed if you get 10 sets of 3 flashes, that is actually a LFC ( Light Flash Code ) 33
Oct 11, 2009 | 2001 Ford F150 Styleside SuperCrew
Check engine codes for 1991 Dodge Spirit LE , light comes on but does not blink then goes out.
Turn key to on, then off, then on, then off, then on & leave it on, (not start, just to on) then count the number of flashes of check engine light. It will flash,then have a small pause, then flash again. It will be a 2 digit number, for example: 2 flashes, pause, 2 more flashes, will be code 22. 3 flashes, pause, then 5 more flashes would be code 35. When you get 5 flashes,pause, then 5 more, That is code 55 which just means end of message. Get back to us with codes & we'll advise of what to look for.
Sep 21, 2009 | 1991 Dodge Spirit
Immobiliser is not turning off and not allowing the engine to start
is it a stick immobiliser?
If your vehicle does not start and the LED continues to flash while the Ignition is 'ON', this means that the Immobiliser system has not recognised the transponder stick.
Simply turn the Ignition 'OFF' then back 'ON' again. If the Status LED continues to flash, move the transponder stick closer to the key barrel until the LED stops flashing and turns 'OFF'.
If the transponder stick on the key ring does not disarm the immobiliser or the
transponder stick is misplaced, you can override the system by entering a 5-digit override number. Each vehicle has a unique 5-digit override number. This number is recorded on the
customer’s owner’s manual. If the customer loses their owner’s manual / override number, the number can be found by locating the vehicle’s Daewoo Stock Number (D.S.N). The customers override number is the last 5 digits of their D.S.N.
Overriding the system using the example 5 digit code 2,1,0,6,2
Important Note: 10 flashes of the Status LED represent the number ‘0’.
1. Remove the Transponder from the Key Ring.
2. With the system armed (LED flashing slowly) Turn the ignition ON/OFF 5 times, with the final position being off.
3. The LED will turn solid red for 2 seconds and then begin to flash.
4. When the LED flashes twice (2), turn the ignition ON. (number 2 was entered)
5. Turn the ignition OFF and wait for the LED to flash once (1) and then turn the ignition ON. (number 1 was entered)
6. Turn the ignition OFF and wait for the LED to flash ten (10) times and then turn the ignition ON. (number 0 was entered)
7. Turn the ignition OFF and wait for the LED to flash six (6) times and then turn the ignition ON. (number 6 was entered)
8. Turn the ignition OFF and wait for the LED to twice (2) and then turn the ignition ON.(number 2 was entered) The LED will turn solid red, which means the system is now overridden and the vehicle can be started. If an incorrect number is entered in, wait 11 flashes then start the procedure again.
NOTE: This is a one-event override. Once the ignition is turned off, the vehicle will passively immobilise after 30 seconds. If your 5 digit override number does not override the system, the chances are that you entered the wrong number. If this is the case, you’ll need to re-enter the override number
and try it again.
Jul 13, 2009 | 1999 Daewoo Lanos
CAR LOOSES BOGS OUT AT HWY SPEEDS AND IDOLOS ROUGH .
Cycle your key on (not start, just on) off, on , off ,on, and leave it on. have paper & pen ready. Watch flashes from check engine light. It will flash quick, pause flash quick. It will be a 2 digit number each time. For example: flash, flash, short pause, flash, flash. is # 22. Flash, flash, flash, pause, flash ,flash,flash. is # 33. There will be a slightly longer pause between codes,(after every 2 digits) then next code starts. 2 numbers again. When you get 5 flashes, pause, 5 flashes = code # 55 means end of message. Check it out and let me/us know what you get.
Dec 31, 2008 | 1991 Plymouth Acclaim
Serial number
FLW500-03143-77238-80660 OR FLW500-06846-68238-49748
Jun 25, 2008 | Macromedia Flash 5.0
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
199 people viewed this question
old marine
old marine
