Question about Home
Our client has a 20 year whirlpool tub and it has two chrome control knobs on it and we have misplaced one Can you help It is about 2'' round and has whirlpool on it turn, high,low jets
    Champion:
  • 248 Answers
Spindles and control knobs should re replaced to-gether can be found online
Posted on Oct 03, 2009
Whirlpool W10140920 agitates with no water in the tub
I've had the same problem..3 times in 2 years.
EVERY time I needed to relpace the switch sensor (behind the water temp knob.) It fixes the problem, but continues to happen. I am going to get a new NON Whirlpool washer today.
Feb 12, 2013 | Kenmore Washing Machines
A CRANE WHIRLPOOL TUB BOUGHT FROM MENARD'S IN THE 1990'S HAS TWO CONTROL KNOBS FOR AIR AS WELL AS AN ON/OFF BUTTON. WHERE CAN I FIND A REPLACEMENT SEAT THAT THE AIR CONTROL KNOB SCREWS INTO A
What you are looking for is called the wall fitting for the air control knob.
If you can email me a picture of the knob, topside and underside I can tell you who made it and if there are parts for it.
send your pictures to: sales@uspartscenter.com
Rod
US Parts Center
888-521-6183
Feb 10, 2013 | Crane & Co Crane Plumbing 2430W Whirlpool...
Three button control panel for jacuzzi tub
Pull off all three knobs and then the plastic graphic rings and you will find 2 screws under each. After removing the screws the whole plate can pop off. If your problem is anything like mine, your air pump is full of water and needs to be replaced. After removing all the screws you can carefully pry it up with a thin tool, it is most likely caulked to the tub. You can find replacement parts and names for it here:
http://www.guillens.com/index.jsp?path=product&part=124772&ds=dept&process=search&text=JAC%20%20G107XXX
Hope that helps
Apr 28, 2012 | Jacuzzi Home
Compatible replacement handles for Moen Garden Tub faucet
I dont know if moen made chrome handles for that valve back then. If they did then they will probably be lever handles but they wont turn correctly unless you remove the cartridges and turn them. Iwould suggest probably replacing the whole unit.
Apr 20, 2009 | Moen Chateau, Two-Handle Garden Tub Faucet...
Program knob on GE washing machine not functioning
Older washing machines had a 2 position knob push or pull to set and the other position to run, also if the timer is bad it can be replaced the parts are still available on the Internet.
Have a good day...
Tim
Mar 26, 2009 | General Electric Washing Machine Chrome...
Jaccuzi hot tub will not heat?
sounds like it maybe the heater again. Have you pulled it out and checked the ohms? it should be at least 10.5 ohms
it could be the thermostat or the pressure switch - if either of those are not working it will not heat either.
Dec 28, 2008 | Home
Tub basket out of round or off balance
normally when one fault is generated after fixing another fault, it is normally down to something caused by the person working on it, this could sound like you have dismantled something on the suspension, you say you changed the pump, (did you tip it upside down to work on it) if you tipped it up to work on it check the suspension legs to make sure they look equal, as the chrome inner drum can not possibly be that far out of alignment, the whole drum unit can be though, thats a different matter, check suspension and get back to me,if i have helped rate me please
Sep 21, 2007 | Whirlpool GHW9100L Front Load Washer
Water leak
Mine also started leaking. Element also too hot. Mine has a 20 year warrenty on the tub (which I was NOT aware of) Repairman came today and the whole tub unit and element will be fixed for free! Look in your whirlpool instruction book to see if yours is warrentied. BTW, my dishwasher is only three years old.
Aug 21, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Home Logo
57 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
