Question about LG Vu CU920 Cellular Phone
My touch screen on my phone is not responding what can cause that
The first thing you should do is turn off your phone. If that does not work and you have warranty on your phone, exchange it.
Posted on Jun 26, 2009
Huawei m866 touch screen stuck on android touch doesnt work
MOBILE PHONE TYPE> HAUWEI M886 ANDROID SMART PHONE
SITUATION > TOUCH SCREEN NOT RESPONDING I CANNOT PROVIDE MAINTENANCE TO MOBLE PHONE... IT TURNS ON BUT CANNOT MAKE SELECTIONS
Jan 22, 2013 | Huawei M886 Mercury - 4GB - Black Cricket...
Samsung a897 touch screen not responding at all
Hello there,
There are two major reasons that could be causing the touch screen not to be responding. The first is if the phone fell and the sensor board got bad, and the best solution is to replace the sensor board. To replace the sensor board is quite sensitive so i will strongly advice you seek advice from a specialist that can assist you with that. But if you intend to fix it DIY way, then you can ask and i will direct you through the steps.
On the other, it might be the screen is weak and needs calibration. To calibrate the screen depends on the type of phone it is. I will advice you go through the user manual for the steps to calibrate the screen of your phone. If you cannot get any response from the screen, i will advice you replace the sensor board. Because calibration requires you to touch the screen and since it is not responding to touch, it will be pointless trying to calibrate.
Thank you for using fixya.
Caseytech
Jun 27, 2011 | Samsung Star GT-S5233 Cell Phone
My samsung touch screen isnt working...the latter half of the screen is not responding and in other areas its not responding where i press. the man at the carphone warehouse said to download some updates...
If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jan 09, 2011 | Samsung SGH-S5230 Cell Phone
My LG dare will not respond when i touch the screen!!!:( it is very frustrating. I have tried turning it off and on and taking the battery off but there is still no response.
Hi, why the touch screen of the phone is not responding is because the touch screen of the phone is damaged, might be caused by hitting the phone on the flow or hitting the phone somewhere.
You will need to replace the touch screen for it to respond to touch.
Take care.
Sep 14, 2010 | LG Dare VX9700 Cell Phone
Touch screen not working properly, i touch down part of screen and it activate upper options. upper part of screen not responding
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jun 28, 2010 | Samsung SGH-D980 Cell Phone
Samsung s5233 touch screen not working
There is a simple answer to this and that is to replace the phones digitizer or touch screen and your problem solved.
br,
www.phonefreedomjamaica.net
Apr 11, 2010 | Samsung Star GT-S5233 Cell Phone
LG Xenon touch screen won't respond. Phone was
make sure that you connected all of the wires. take it to a techy just to make sure
Sep 27, 2009 | LG Xenon GR500 Cell Phone
Touch screen do not respond
At times, Touch screen does not respond and phone cannot be unlocked by no means, Problem do not get solved even after restarting phone, removing battery & reinserting etc.. This happend typically during nights when the phone is not used and in the morning, touch screen does not respond to do any activities. after installing a software i had a hard reset, after that my tuch screen did not work.please help meeeeeeeeeeee ! !
Jul 30, 2008 | i-mate JAM Pocket PC
Touchscreen does not respond to touch
This is straight from Palm Support...
1.Press and hold the UP button on the front panel of your device.
2.While holding the UP button, use an unfolded paper clip, or the reset tool at the tip of your stylus, to gently press the RESET button inside the hole on the back of your device
3.The Palm Computing Platform screen will appear. Release the UP button when you see it.
Dec 11, 2007 | Palm Treo 600 Handheld
LG Vu CU920 Cellular Phone Logo
174 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
