Question about HP Business Notebook 530
My computer does not have sound.
Whenever i open my computer i do not hear that opening sound and the screen solution is very poor ,some one told me viga drivers are missing.It also does not have microsoft word.
  • bmangeziman Jun 27, 2009
    the sound is not on mute maybe the driver are not installed.
  • 3 Answers
Your sound is mute or not install driver.
Posted on Jun 26, 2009
I have installed t sound driver.. but i can hear a constant sound whenever i use it and if i talk over t headfones even the other side who is hearing me can hear the noise also... how can i solve this??
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Feb 14, 2012 | Intel D915GAV Motherboard
My monitor keeps going black you can hear the sound but no picture only black screen
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 24, 2010 | ViewSonic VA712B 17" Flat Panel LCD...
Buzzing sound coming from all speakers
Can't say for sure (not a lot to go off of) but whenever i hear a buzzing sound from my speakers, its because of a poor connection (broken/exposed/bent) of the audio cables (whether its the red/white, or headphone jack (computers)).
Oct 03, 2010 | RCA RT2500 System
Monitor brighness shuts off
It sounds like the backlight circuits are not working, it can be due to bad power supply.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 13, 2010 | Acer P191WBD LCD Monitor
I have no audio device can not turn speakers on
Good day heigei, hi if you turn on the speakers but no ON lights came on, the problem is your Speakers' power supply stage, either a fuse opens (most likely) or something got burnt from the plug to the transformer, then to the rectifier diodes (got shorted then fuse opens) or to the regulator section. check also the power switch for poor contacts, of course you may need to open the speakers, If by any chance you hear something like hum.... check for open signal wire, check the IC amplifier also, a bad IC amplifier produce no sound or produce a loud humming/cracking sound. If you have no idea of what im talking about, have it checked by a technician. thats it.
Jan 20, 2010 | Altec Lansing VS2121 Computer Speakers
Won't produce sound batts charged says it is paired says it is connected
It will produce sound when you click open the Volume icon in the system tray in the right bottom corner of the screen. Here you will find that the MIC has been muted (Old habit of Windows). Remove the tick from the box of mic and save. Now you and others will hear you talk. And remember to unmute it whenever you want to talk to anyone.
Dec 13, 2009 | Computers & Internet
CD's,such as games won't open
Does your screen get squiggly while doing other things? It sounds if you have a problem with your monitor or cable or the video card.
Jun 11, 2009 | Acer Aspireā„¢ T180 PC Desktop
Samsung 40 INCH TFT-LCD Cant start up at all .
The noise you are hearing is the power supply attempting to start up. Unfortunately, a component has failed inside the power supply circuit. Most likely it is a capacitor. The good news is that the set should still be under warranty and the repair should not cost you anything. The bad news, is that the service person may not have a replacement power supply board with him/her when he/she arrives. This should be a quick fix as the replacement board is relatively easy to change.
Dan
Feb 04, 2009 | Philips Televison & Video
LG Plasma 50PC5D Help
sounds like the internal screen has cracked look closeley to see if you can see any cracks if so new screen im affraid if no cracks suspect power board
Mar 20, 2008 | LG 42PX5D 42 in. Plasma HDTV
HP Business Notebook 530 Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
