Question about Canon imageRUNNER 7200 Copier
How to check hopper motor working or not - Canon imageRUNNER 7200 Copier
Canon ir2535 e00020 repair
Dear in most cases if toner refilled (or the life of the hopper assy.)the worm gear of the hopper assy. worn out. so the sensor at developing assy.detect no toner flowing to the developer from the hopper assy. where as the hopper assy. sensor detects toner. check the sensor, If you have knowledge enough to dis-assembly the the hopper assy. check the worm gear connected to a small motor driving toner gear. clean the sensor( may toner got inside the windows of sensor, clean it). check the harness, check the DC_CON pcb. Note if no experience donot open hopper assy. take assistance of trained engineer. Thanks.
Feb 21, 2015 | Canon Office Equipment & Supplies
The problem is about error 000002 0000 for my ir6000
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Feb 14, 2013 | Canon imageRUNNER 7200 Copier
Error code coo72
Your Hopper motor is not working, 72 is coming from the Toner Hopper motor....check motor check gears and check developer life,,,,,,
Jun 16, 2012 | Minolta EP4000/5000 CS/PRO Copier
I have a problem with code E020 (canon 1120)
E020 - The toner is not adding correctly into the developing assembly.
1) If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) If the hopper is 1/2 full or less, the worm gear splits under normal use.
1) Advise customer to add toner only when the toner light is lit, right away, and replace toner motor, or 2) Just replace toner motor (FH7-1762-030).
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller. It has been noted that some DC controllers do not provide sufficient current to drive the hopper motor. Replace the DC controller COL97.08.25 M0000244.txt.
Apr 14, 2010 | Canon CLC 1120 Color Copier
Error code e000020 in ir6000
E020
General condition
General condition
Oct 25, 2009 | Canon imageRUNNER 7200 Copier
Whirlpool GS6SHAXLB03
IF YOU REQUIRE A MOTOR CHANGE FOR THE ICE DISPENSER AS A WHIRLPOOL AGENT IN SOUTH AFRICA TO MY KNOWLEDGE THE MOTOR SITS BEHIND THE IS HOPPER.REMOVER THE HOPPER AND IT WILL BE VISIBLE.GOODLUCK.MOHAMED
Sep 10, 2008 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Water/ice dispenser
it is possible for it to be the solenoid, as for removing the motor you would need the users guide to tell you specifically, as for the ice problem is the door from the hopper and the schute that the ice goes through stuck?
Jul 05, 2008 | Refrigerators
Error code E 000025-0001
 hello i m ramy,first  replace the toner bottle, second check the hopper motor connection,
 hopper motor unit gears.
or test if there 24 vdc .to the motor
Mar 27, 2008 | Canon imageRUNNER 5570 Copier
Toner
Di200 [Subject] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good. [Description] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good.
[Solution]
CAUSE: Inside the sub hopper, the magnet (P/N 9326-2900-06) may be catching on the inside of the hopper, preventing proper actuation of the Sub Hopper Toner Empty switch.
SOLUTION: Make sure that the actuator can move freely up and down when no toner is in the sub hopper.
Dec 21, 2007 | Konica Minolta DiALTA Di200 Copier
CANON CLC1000
E020 refers to incorrect operation of toner moter, jammed up toner hopper or motor stuffed.... If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. If the hopper is 1/2 full or less, the worm gear splits under normal use.
add toner only when the toner light is lit, right away, and replace toner motor.
Dec 02, 2007 | Canon CLC 1000 Color Copier
Canon imageRUNNER 7200 Copier Logo
42 people viewed this question
Clive
Clive
old marine
old marine
Ekse
