Question about Samsung C417 Cellular Phone
Front Display screen
The image of an elongated bright yellow leaf, outlined in bright blue, is superimposed on the front screen. It is slanted from the bottem left to the top right of he screen.
I have changed the wallpaper settings several times. No matter what screen I select the leaf is superimposed on the screen masking the wallpaper.
Your help will be appriciated.
  • 626 Answers
Re: Front Display screen
It is not a leaf. The inside glass in the front of the LCD screen is cracked.
It will need to be replaced.
Best of Luck.
Posted on Nov 06, 2007
0 characters
3 Points
I have a hiphone 4s and safari is in Chinese. How do I change it to english
  1. On the Home screen, locate and tap the icon that features the image of a gear:
  2. When the following screen appears, locate and tap the section that displays the same gear icon:
  3. On the next screen, scroll down and locate the group of settings that offers four options. Tap the third option in this group:
  4. On the next screen, tap the first option:
  5. Pick your language from the list, and then tap the bright blue icon in the upper right:
  6. After a few seconds, your iPhone, iPad, or iPod touch should return to the Home screen and display the language you selected.
Apr 20, 2012 | Apple Cell Phones
Horizontal lines on front display
The screen has cracked. If this isn't a physical damage andthe phone is under warranty; you must take the phone to the nearest nokia care and avail the warranty.
Oct 19, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
Blank screen
Goto settings & tools, then goto display setting, then brightness.
Then goto messaging and then setting and then callback #
Dec 30, 2008 | Motorola Mobility MOTO W755 Cellular Phone
E815 cell phone
the phone has a flex cable that connects the bottom of the phone to the top. after repeated opening and closing the cable gets damaged. contact you local repait tech to change the cable or contact they can do the repair for $40.
Jul 10, 2008 | Motorola Mobility E815
My apple iPhone display screen is completly black but the touchscreen is still working
just had same problem latest 3g phone black screen scared me waiting for important text,hold power and front button simultaneously worked as you all have been discussing ,reboots after a min, had dropped mine last week recommend getting hard back that clips on ebay five pounds n screen cover in included
apple rocks
Jul 05, 2008 | Apple iPhone 3G
Samsung u340's front screen is very dark
Probably need your brightness turned up. Go to menu, then settings, then display settings, then backlight, then brightness.
Apr 11, 2008 | Samsung SCH-u340 Cellular Phone
Front display is blank
this is a tech fault which will require a tech to deeal with it hands on
Dec 09, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Razr front screen blue, inside screen white/blank
this i did find a guide to opening the moto up .
hope this helps you out.
Nov 12, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Image on screen
Yes... The LCD screen is faulty and will have to be replaced in order to remove the "pile of straw" , You can do this by removing the screws below the battery with a t7 torx screwdriver , then you will be able to remove the front of the phone and ther you will see the LCD screen and is simple to replace, Hope i helped :~)
Oct 09, 2007 | Motorola Mobility L6 Cellular Phone
Samsung C417 Cellular Phone Logo
90 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
