Question about HP DeskJet 5550 InkJet Printer
Both lights on the printer are flashing and the printer ribbon will not line up
  • 2,567 Answers
Check page 10 in the manual at this link:
http://h10032.www1.hp.com/ctg/Manual/bpd09384.pdf
If the "Resume" & "Power" buttons & lights are the ones you refer to, then here is a page explaining how to resolve this issue:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=71895&prodTypeId=18972&prodSeriesId=71895&objectID=c00681585
Posted on Jul 21, 2009
Evolis Primacy printer the top light keeps flashing. If you take the cards out of the printer the light quits flashing
If you're referring to the light just below the power-button light, and it is flashing, that usually indicates the printer is unable to feed a card. But you later indicate that it did feed the card, as it was pulled through and ejected after restarting the printer. Some other things that can be occurring:
1. The Primacy has a low-card indicator/sensor where that light will flash if you have fewer than about 20-25 cards loaded. Fill the hopper and see if the behavior changes.
2. The card not printing/rejecting may be a symptom of your having the driver set for a different ribbon than you have loaded in the printer. Evolis puts the part-numbers on the side of their ribbon cartridges, so make sure you've selected the right one in the driver.
3. You may be out of ribbon. Each ribbon cartridge has a fixed number of prints that it will do. This is electronically controlled and limited through the use of an RFID tag embedded in the ribbon cartridge. For example, a R5F008AAA ribbon is limited to 300 prints. So, while there may be ribbon remaining on the spool, if the ribbon has done 300 prints, it won't allow you to print more and will also act as you describe.
4. There are a number of other potential causes and fixes beyond these most common ones - driver settings, firmware updates, calibration routines, etc. - should the above not resolve the issue.
And, if I can get on my soapbox for a moment, you really should establish a good working relationship with an Evolis authorized dealer (like us). These plastic card printers really exist in a technology niche and, as you are seeing, require some specialized knowledge and expertise. Most authorized dealers will provide at least a basic level of support and service via phone for free to their REGULAR CUSTOMERS. That means that if you buy your printer and supplies from them, they're happy to help you out when the need arises.
However, if you want to be a do-it-yourself guy, searching the web for the rock-bottom lowest price on your printer and supplies, well ... you get what you pay for.
Jul 24, 2017 | Evolis Office Equipment & Supplies
I have a Zebra 105 SL, I have the ribbon installed but the printer tells me that the ribbon is out. I've tried changing the ribbon and labels out but as soon as I power it back up and try printing again...
Calibrate the printer from the setup menu.
You'll (1) Load the label backing with the ribbon (2) remove the ribbon - just shove it to the right, out of the way of the ribbon sensor (3) reload the label and ribbon.
The printer will run a number of labels out.
Feb 16, 2011 | Zebra 105SL Thermal Label Printer
Power light lit Pause light lit data light flashing and display saying printer idle , ribbon out
Press the pause button to take the printer off pause...
The data light is flashing because it has labels to print...
Check to be sure your ribbon is loaded properly.
Jun 20, 2010 | Zebra 203DPI Printer
I have a Z140XiIII that used to have a ribbon and thermal transfer stock. we changed the stock to not require a ribbon, so we removed the ribbon and set the menu to Thermal direct. labels print OK but the...
If the printer is flashing "Ribbon in" then it sounds like the printer setting to Thermal Direct is being changed back to Thermal Trans. Verify this after sending a format. This is very common because the printer is bring over-ridden by the software and/or printer driver when you send a format.
Look for a setting in the software / driver for direct thermal and make the change there.
Hope that helps.
Apr 21, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Red line indicate
there are many possibility,
1. wrong ribbon installation , make sure there's nothing wrong, if need u may change the ribbon sensor
2. label not detected, change the label sensor
3. Printer need calibrate, turn off the printer, press and hold the feed button then turn on the printer after it flashes a red light , let go the button, it will do a manual calibrate, wait until it finished, it should be back to normal
Aug 16, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Bad print out
I would recomend checking the ribbon cartride fitted in the pritner. Ensure the ribbon is correctly mounted on the ribbon drive shaft.
Ensure the ribbon is not jammed.
Ensure the print head gap is not set to close the ribbon is becomming jammed
Try changing the ribbon cartridge for a new one.
Dec 30, 2008 | TallyGenicom 2348 24WIRE 480CPS Draft 136...
Z600 wont print, ribbon error
in the switched at the front of the printer you can configure it to direct thermal mode.. or if you are using printer driver please configure it also to direct thermal mode..
Jul 08, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra s600
The factory default setting for the S600 is thermal transfer (ribbon). depending on your OS there is a command that can be echoed to the printer to change the setting to direct transfer (non ribbon). It sounds like your printer thinks is should use a ribbon and in fact you are not using a ribbon. Here is the procedure I use to get the ribbon motor to turn on:
1. start with the printer turned off.
2. open the printhead, retract the ribbon completely onto the supply spool. leave the printhead open.
3. Press and hold the top three buttons (PAUSE, FEED and CANCEL) while turning on the printer. When the botom couple lights turn off release the buttons.
4. When you are left with the power light on and the printhead light blinking reinstall the ribbon and close the printhead.
The printer will autoclaibrate and run a sensor test.
Once complete the take up motor should have turned on and you should be able to use thermal transfer labels and a ribbon.
Nov 21, 2007 | Zebra Stripe S600 Thermal Label Printer
Alarm
look in the manual for alarm codes, on? flashing?
possibility something wrong with the carriage, this is the black piece where the ribbon sits on, there are gears in there that will break, very common
1) take out ribbon and print, if it continues to print a few lines without alarm, it's a bad ribbon.
2)turn off printer and move the carriage my hand from side to side, should be smooth, if you hit a bump or tick, it's the carriage.
Sep 14, 2007 | Office Equipment & Supplies
HP DeskJet 5550 InkJet Printer Logo
116 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
