The issue you're experiencing with your Denon receiver AVR-1700 may be due to a few reasons. Here are some troubleshooting steps that you can try:
Check the connections: Ensure that all cables are securely connected to the receiver and the speakers. Make sure that the input source is selected correctly on the receiver, and the volume is turned up.
Reset the receiver: Sometimes, resetting the receiver can resolve issues with the sound. To reset the Denon AVR-1700, turn off the power, and unplug the power cord for about 10 minutes. After 10 minutes, plug the power cord back in and turn on the power.
Check the speaker settings: Ensure that the speaker settings are configured correctly on the receiver. Check that the speaker wires are connected properly to the receiver and the speakers. Make sure that the speakers are not damaged or blown.
Check for firmware updates: Make sure that the receiver is running the latest firmware. Visit the Denon website to check if any firmware updates are available for your model.
Check for hardware issues: If none of the above steps work, there may be a hardware issue with the receiver. In this case, you may want to contact Denon customer support or take the receiver to a professional repair shop for further assistance.
Hopefully, one of these solutions will help you resolve the issue with your Denon receiver AVR-1700.
Save the information currently stored in your Denon receiver, such as device commands and multi-zone controls. Some Denon receivers can control multiple rooms and each room needs to be setup properly to provide the correct controls. If the receiver was installed professionally it may be best to contact the installer before resetting the device.
Press the "Power" button or the "On/ Standby" button to shut off the receiver. On some receivers it is best to press the button on the device instead of the remote as the remote will normally put the receiver in standby mode. Ensure the display and all other lights on the device are off. Do not unplug the Denon receiver as it will not reset.
Press the "Power" button and at the same time press two buttons on the front panel, which are determined by the model Denon you own. Most receivers identify the two buttons inside the user's manual, while some older Denon receivers require you contact Denon for the right button combination. For example, some Denon models require the "Standard" and "DSP Simulation" buttons to be pressed simultaneously.
The display will start flashing at about one second intervals. Release the two buttons. Turn on the receiver by pressing the "Power" or the "On/ Standby" button to verify the previous settings and saved radio stations have been erased. If the interface does not flash, the reset was not complete and needs to be re-done. Re-enter the previous settings to ensure there are no further issues with the receiver.
Sounds like you system is set up to only provide output current when not charging via the array... its common... shut off or disconnect panels and your problem is solved but the batteries won't be receiving any charge obviously... this set up is used when the systemhas nothing to limit or control the current produced from the arrays/panels from going directly to the attached output devices. This is typical in small pv systems.
SWITCH OFF THE UNIT..PUSH AND HOLD DOWN BOTH SPEAKER A AND SPEAKER B BUTTON WHILE HOLDING DOWN BUTTONS TURN ON MAIN POWER THE DISPLAY WILL FLASH WAIT FOR 3 FLASHES THEN RELEASE. THIS WILL RETURN EVERYTHING BACK TO RFACTORY DEFAULT
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Hope your under warranty mate and if so hope its not in Australia as they cannot fix this problem. My denon was allegedly fixed twice but has now failed a third time (just out of warranty) and denon have turned their back on me. SHAME ON YOU DENON.
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
