Question about Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas
Do not know how to turn on the gas for pool heater
There is no on/off on my gas lever. , so do you put it horizontal or vertical?
    President:
  • Teledyne Laars Master
  • 1,378 Answers
Probably a better way to say it would be parallel or perpendicular. Parallel is open, perpendicular is closed.
Posted on Jun 27, 2009
Where is horizontal output ic in my t.v?
There is no horizontal oscillator IC. The horizontal oscillation is generated and outputted by the main system control IC LA76810 itself. Refer some circuit diagrams using LA76810 to get more details about the horizontal oscillation output from the IC. Measure the frequency at that output pin. It should be some ever near 15.62KHz.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the IC number, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 31, 2015 | Televison & Video
I have a 20lb propane tank fells half full or better grill lights but won't heat up why? Put new tank on works fine.
Gas may have settled. Turn it upside down several times. Usually happens when it gets cold outside.
Oct 12, 2014 | Grilling
I have a 1986 Suzuki Cavalcade LX. The Gears are very hard to shift, sometimes I can't get the shift lever to move at all. I can manipulate the clutch lever in and out while exerting pressure on the...
First thing to check is the alignment of the shifting mechanism. The vertical parts at either end of the horizontal adjusting rod need to be vertical and parrallel. Move the clamp end to achieve this, then adjust the adjusting rod to get the front one vertical/parrallel. Then lubricate the balls at each end of the adjusting rod. Have you joined the worldwide yahoo email group, it has over 1400 members and there maybe one near you. Check it out via www.suzukicavalcade.com
Jul 29, 2011 | 1986 Suzuki GV 1400 Cavalcade LX
I was cleaning the dust out of the feed dog area and somehow disconnected the feed dog from the lever in the back that raises it and lowers it. How can I reattache them?
A feed system for a sewing machine having a frame, a horizontal arm shaft journalled in said frame, a vertical arm shaft extending downwardly from adjacent said horizontal arm shaft, means rotatably connecting said horizontal arm shaft to said vertical arm shaft, said feed system comprising a cam fixed to said horizontal arm shaft, a sheet metal feed fork having parallel bent over portions at one end thereof embracing said cam and in driving engagement therewith, a feed rock shaft supported in said frame and having an arm connected to the other end of said feed fork, feed regulating means carried by said frame and connected to said feed fork for converting motion induced by said feed cam to oscillations of said rock shaft, said rock shaft being formed with a pair of upright rock arms on the other end thereof, a horizontally disposed U-shaped sheet metal feed dog carrier having each end thereof connected to one of said upright rock arms, said feed dog carrier having a horizontal shelf extending from the base of the U between the ends thereof, said shelf supporting thereon a feed dog, means for attaching said feed dog to said shelf, a stud affixed to said base of said feed dog carrier beneath said shelf, a sheet metal lift lever pivotally supported on a horizontal axis in said frame substantially parallel to said rock shaft, said lift lever having a slotted end for engagement with said stud extending from said feed dog carrier, said lift lever having the other end thereof supporting a cam follower adjacent said vertical cam shaft, and a lift cam removably affixed to said vertical cam shaft and in engagement with said cam follower on said lift lever.
Take care.
Oct 20, 2010 | Kenmore 19110 Computerized Sewing Machine
Is it normal to run a 16" vertical tie in to a horizontal exit
No, Exhaust vents on heaters should always maintain vertical orientation because heat rises and creates a natural drafting drawing the fumes out. You have a monoxide poisoning situation otherwise.
Oct 20, 2009 | Mr. Heater Natural Gas Garage Heater -...
Cannot start teledyne laars pool heater
Hi should be horizontal crack pipe and see if gas is there do this with every thing off then pruge pilot line should have gas then
Jun 26, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Just wanted to determine, for a Kawasaki bayou 220, the fuel lever positions for fuel Off VS On (ON = vertical?).
The valve is open when the lever and valve are parallel. Generally that is down. When the lever is pointing across the valve it is closed. Think T vs. I. If the lever and valve cross it's closed, if they go the same way it's open.
That applies to a two position valve, if your Bayou has a reserve postion it could be different. That would be three positions and across one way would be open, down would be reserve, and across the other way would be closed. Should be marked on the petcock if that is the case.
Mar 13, 2009 | 2003 kawasaki KX 250
Oki 5600 & 3400 toners
This error is toner not recognized
Follow the instructions for possible fix.
INSTRUCTIONS TO CHECK REFLECTOR OPERATIONS
(1) Open the poly bag, and take out the Toner-cartridge.
(2) Remove the tape to the position like the figure.
Tape
(3) Hold the Toner-cartridge horizontally, so that the Lever-sensor may go up and down
vertically.
Lever-sensor
(4) When it does not see the Lever-sensor like the figure, turn the gear in the direction of the
arrow, and it tries to see the Lever-sensor.
Gear
(5) Return the tape to former position.
(6) Put the Toner-cartridge vertically.
(7) Move Lever-sensor like the figure.
Lever-sensor
(8) Confirms the Lever-sensor is returned smoothly.
Lever-sensor
(9) Repeat (7) and (8), 3 times. The Toner-cartridge is wrong when the Lever-sensor does
not work from the position of (7) or when it does not return smoothly
Mar 05, 2008 | OKI C5200n Laser Printer
Teledyne Laars Laars Lx Pool Heater / 400,000 Btu / Propane Gas Logo
74 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
