My yamaha receiver v383 keeps shutting itself off , even when nothing else is plugged into it , I must unpllug it and plug it back in to get it to come back on but it still only stays on for about 3 seconds
smarthome2
  • 1114 Answers
SOURCE: Yamaha RX V2400 keeps shutting off
When it shuts off, does it display anything on the front like "ck speakers" you could have a shorted wire or bad speaker. Sounds more likely than a bad receiver. Yamaha is pretty bulletproof in "self preservation" circuitry! about the only thing that takes them out is lightning and major power surges. I have been selling and installing Yamaha receivers since 1995 and have only ever seen one with a problem that was unrelated to power. and I've done hundreds. If your not using HDMI, and the Video portion of the receiver, I would definately keep the unit $ 1500.00 is no cheap receiver. Try disconnecting the speakers, then turn on the unit with a source connected like cable/sat/fios on then crank the vol and let it set, if it cuts out, yes you've got a problem internally, however, I would stronly suggest metering all of the speakers and wires for shorts. There is an internal fuse as well right near the power cord, you have to pop the top to get to it, If you have a multimeter check the fuse with resistance tone. If you get tone, you have a good fuse if not If you need to replace it. They can be found at Radio Shack etc. If the fuse is OK, chances are you've got bad transistor(s) and needs to go to service. Repair should be under 200, well worth it. If you have further questions, post a comment and I will get back to you ASAP. Hope this helps
Posted on Jun 06, 2009
petraman7
  • 1175 Answers
SOURCE: yamaha rx-v461 not working
Does the reciever have separate speaker switches?
Try turning off the speakers and turning on the amp.
If it doesnt have speaker switches , make sure ALL the speakers are connected at both ends and try turning on the amp again.
Posted on Feb 04, 2009
tech48
  • 624 Answers
SOURCE: receiver randomly shuts off during play
This is the "Protect" mode. It is either a bad speaker, or not good ventilation, or a channel going out in the receiver. Please provide more details about the problem so I can help you better. How long is it playing before it shuts off, does it shut off even if the volume is low? Disconnect the speakers form the receiver and then turn it on and let it play without speakers, if it still shuts off then the problem is not the speakers. More information is needed to better diagnose this problem.
Posted on Feb 06, 2009
  • 8 Answers
SOURCE: receiver keeps shutting off after 3 seconds. what
If you are comfortable opening the unit, start unplug the sub board when the unit is shut off and then turn it back on.
Posted on Sep 10, 2009
Hitachi-mex
  • 26 Answers
SOURCE: Receiver turns for a fews seconds then shuts down
Hi.
If the word "OVERLOAD" is in your display, we have a bad channel.
But if only turn off, and the standby led is on all the time, you need change a couple of resistor of 10 Ohms at 2 Watts in main board. But you need disassamble a must all the amplifier. A lot of work, but cheap part.
Best regards.
Posted on Oct 23, 2009
Yamaha Receiver won't turn on after USB plugin in. Help!
Unit is in protect mode. Sometimes an ipod draws too much current through the usb jack and causes the unit to shut down due to an abnormal voltage being detectected. Press and hold the 'info' and 'tone control' buttons and push power. This should turn the unit on. Turn it back off and turn it on again and should power up normally. If the ipod continues to make the unit shut down when plugged in, try and make sure it is fully charged before plugging it into the receiver - this may help.
Apr 13, 2014 | Yamaha RX-V375
Yamaha RX-V1600 shutting off
try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode
happend to me on RX-V592
Jan 21, 2013 | Yamaha Audio Players & Recorders
My yamaha rxv595a keeps on shutting itself off when im watching movies as soon that it gets loud it shuts off but its not even that loud how do i fix this problem i tried the ohms switch in the back and it...
That is a safety switch in most receivers. When something gets too loud it cannot give the load off to the speakers and shuts off to protect itself. This can mean that the receivers getting old, or that you might need to split the job. You might need an stereo amplifier to split the job. Check the cables and speakers. Recievers can only give so much to so many speakers at so much sound. That is what the whatts are for. The more whatts the better, the lesser whatts, the lesser speakers its going to be able to handle at high volumes.
Feb 28, 2011 | Yamaha RX-V595A Receiver
Can I hook up my yamaha receiver to soundbar
can I hook my yamaha rx-V465 to my vizio soundbar? When I soldered the rca plugs on to the speaker wire and connected my center channel on the receiver now ther receiver randomly shuts itself off.
Nov 21, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
My DCT6200 cable box keeps shutting itself off and then turning back on. I have already tried resetting it by unplugging, but that has done nothing. Even after I have turned off the power and left it...
1) have you tried changing that box in that room to another and the box from the other to this room. That may give you an idea of either power or signal strength issue.
2) after it resets does a "dl" show up on the box front. if so it is trying to download a firmware/software update and everythime you power cycle it starts over.
3) turn the box off then hit select and go to option 8. there should be 4 modules enabled.
4) you may need a new box
Aug 02, 2010 | Arris DCT6200 DTV Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Home Theater Receiver keeps Shutting Down
Have you tried a different input on your TV? HDMI communicates both ways. You could have an issue with the input port on the TV. Try using Component. If you still have issues post a reply and we can dig further into it. Hope this helps
Jun 04, 2009 | Yamaha RX-V2600 Receiver
Yamaha RX V490 Turning itself Off
The amp is in protect mode which means that the output section has a problem. With nothing connected, there are defective parts inside the unit. This type of problem is not likely to have been caused by any shipping damage. I would guess that the output transistors are shorted.
Dan
Jul 22, 2008 | Yamaha RX-V490 Receiver
It keeps turning off
The audio output ICs or transistors are blown. Solid state elctronics are not very forgiving when they are shorted. it takes one tiny instantance and the componets will fry. sorry to be the bearer of bad news but you will need to have this unit serviced or replaced, And never ever work on any type of electronics with the power still on. Good Luck
Apr 07, 2007 | Yamaha HTR-5830 Receiver
666 people viewed this question
 Grubhead
Grubhead
