I've checked the voltage (120v steady), replaced the GFCI circuit breaker, replaced the pump, checked the in ground wire for loss, replaced the junction box, cleaned and re-validated the grounds. If I disconnect the pump, everything works no fault. If I connect the pump and configure it to 220v, it works until the thremo-sensor kicks it off. PLEASE HELP
SOURCE: Wiring Hayward pool pump
John what you have is a 240 volt motor on that pump. It will not connect to a 120 volt cord. You'll have to get a different pump.
Sirwriter
SOURCE: Hayward Super Pump not turning on
it sounds like your pump is stack it could
bee that something is stack in the pump,
try somehow to turn the motor to see what is binding
get access thrue the pump.
G
SOURCE: HI! Just bought a Hayward
I have a few ideas. That the pump didn't come with a cord suggests that it should be hard wired(not a plug in) and you should check the product info plate to see if it requires 110 or 220v. and that the circut that it is being connected to can handle the start-up amps. Mine required a 20amp 220 circut of it's own. When wireing the hot wire(hopefully black) should be connected to the copper clored screw and the white one to the silver screw, the bare /green wire to the green screew. There is also the possibility that the new unit is defective !! can be checked with an ohm meter.
SOURCE: I have a Hayward Max-Flo Pump model no. C48K2N143B1!!
To the motor housing. This will be a green screw on the top of the wire box in the back of the motor. It will be inside the wire box but on the outside edge of the housing.
SOURCE: can u hookup hayward Aquabug to intex above ground
You Aquabug pool cleaner works WITH your pools filter. You much connect the cleaner to your filter system and the filters suction is what powers the cleaner. Since they operate together, you should always run your filter while you are cleaning, but it will never operate in its normal capacity since you are using it for a different purpose. Here is a copy of the users manual if you have any questions about how the cleaner works.
http://www.backyardcitypools.com/images/Hayward/Aquabug-Manual.pdf
