Laptop is not working
I ve got toshiba laptop U400 - 112. i ve been trying to switch on the latop but it doesn't work. there is a red batery sign on the keybord and the battery makes a slightly noisy sound.don't know what to do.
  • 674 Answers
Remove the battery fact the connect the charger direct, then turn on you laptop if the same problem.. check the baord where comes out the sond,, check the ram ro boar
Posted on Jun 26, 2009
Power button
try taking out the batery, and disconnect the charger. then press the ON button for about 30 seconds. put the batery back in place and try starting it up again. hope it works, it did for me :)
Sep 26, 2013 | ASUS K40IN-A1 Notebook
I'm using a Toshiba L505-10W. recently i've installed windows 8 consumer preview. my wireless doesn't turn on and the flash cards doesn't work either. realized that even my bluetooth d
The drivers for the hardware don't exist for windows 8. You need to format. turn on holding the 0 key. follow steps to set to factory defaults, save your pictures and documents first cause this will erase them.
Jul 01, 2012 | Toshiba Computers & Internet
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
My Toshiba L505 ES5018 FN keys is not working
Hello. It's possible the driver for the wireless card(network interface controller) was not installed properly. Try to download the drivers from Toshiba website and install on your laptop. You may get the WiFi Driver from this link
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2520800&rpn=PSLU0U&modelFilter=L505-ES5018&selCategory=2756709&selFamily=1073768663
There's two WiFi Driver available, try to use the Realtek first and if it doesn't work try the Atheros. If WiFi driver installed correctly you should no longer see the "!" symbol and you will be able to enable wireless on your laptop using FN key combination.
Hope this works for you.
Nov 18, 2011 | Toshiba Satellite L505ES5018 Laptop
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
Problem: A100 flashing Amber light but won't turn
Check your charger. It seems to indicate low batery and the charger may not work or the power socket has a faulty connection. Check for phisical damage in the power socket of you laptop.
Try to twist it or even push it in a bit while trying to switch on. Try also to remove the baterry and use the charger power supply only.
If nothing happens its very likely to be the charger.
Jul 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
Fujisu laptop batery not chargin
try to check if other battery is working when being charge,if the problem is in ur battery u have to return and ask for replacement fron the store where you purchased it.nobody can repair battery pack.tnx
Jan 10, 2009 | Toshiba Satellite A105-S4004 Notebook
Internet explore / system restore
hi sir, i ve an latop toshiba which ,i change from vista to windows xp service pack2 and the enternet is not working.
please help me
thank you.
Jul 23, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba tecra 9100
i have lost sound card driver of tecra 9100 laptop.Where will i get the sound card drivers.
riiky
Feb 11, 2008 | Toshiba Tecra 9100 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
