Question about Garden
Need to change the motor oil in my lawn mower, **** Super Z with Honda 24 hp motor. How many quarts of oil does this require?
    Problem Solver:
  • 5 Answers
You should have a GXV670 Honda on that beast. If so, then 2.5 quarts with a filter change.Good luck.
Posted on Jun 26, 2009
How much oil does it take to change in a honda 5.5 engine
most push mower hold about one half of a quart put in a half and check it
Apr 26, 2012 | Troy Bilt 5.5hp Self Propelled Mower
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Jul 21, 2010 | Toro Super Recycler Super Bagger Lawn...
Oil change
Probably about 1 1/2 quart ... you will have to confirm the fill with the dip stick. Do not over fill .. Put in 1 quart ... start the engine ... let it run for 30 seconds of so ... shut it off and check the dip stick.
May 31, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How to change oil in poulan pro 650 series model hp-22 mower
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Apr 14, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Lawn Tractor 1000, oil chg
there is no filter. but when you drain the oil. start by adding a 1/4 quart and check the level. if still low keep adding (little at a time) until it reaches the full mark on dipstick...good luck
Apr 03, 2010 | Garden
What is the oil capacity of the briggs ans straton i/c 17.5 hp ohv motor
Approximately 40 ounces. Put in a full quart first, then add about 1/4 of the second quart and start checking the dipstick until you are at the full mark. Each time you add more, let it run down into the engine for a minute or so before checking or you will get a false reading. If your engine has an oil filter and you changed it, figure about 2 extra ounces for the filter
Oct 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to know how to change the oil in my Honda w/Troy Bilt motor 11A-542q711 w/overhead cam GCV 160.
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Jun 06, 2009 | Garden
Garden Logo
498 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
