Question about GE GSH22JFR Side by Side Refrigerator
The freezer unit has had to be replaced 4 times in 2 years.
  • 351 Answers
Wow! why?....maybe a new fridge would be better
Posted on Jun 26, 2009
4 year old Samsung fridge rf4287hars, flashing 22 e and 5 e codes after being unplugged for a short time. Unit isn't turning on...need help!
You need a new fan and defrost sensor on the side opposite your freezer that are the 2 codes present.
Feb 14, 2015 | Samsung Refrigerators
Why does My GE freezer thaws out about twice a year
The freezer section of a refrigerator should go through a defrost cycle 2 or 3 times a day. If it doesn't, the coil will ice up and fail to produce cold air, causing the freezer to warm up.
If your unit is older, try replacing the defrost timer. If it's a newer model, then, unfortunately, it's likely a bad motherboard (made in China) which can only be replaced in its entirety (not repaired).
Apr 07, 2014 | GE Refrigerators
GE side by side refrigerator model GSS22JEPD freezer ices up.
remove the freezer shelves and remove rear inside panel in freezer,under the evaporator located here theres a heating element,it has probably opened up and can no longer heat,this is a very common problem with g.e. SxS refrigerators,replace it by unplugging unit,then remove 2 screws holding heater bracket and unplug heater and replace g.e.heater part # is WR51X10101
Jun 16, 2012 | GE Refrigerators
Lost cooling in refer and freezer. Heard a buzzing every few seconds from the lower right. After a day the unit again cooled. Had the Sears tech out today and was told that the compressor had locked up,...
Sorry to read about your problem, I hope this helps you out.
your type can carry a 2 to 5 year warranty...
it is easy to check comp for start up....so if the tech says locked up its locked up....
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The freezer wont freeze and the back panel is covered in frost
Hi and welcome to FixYa. I am Kelly. Your refrigerator is not defrosting automatically. This can be caused by:
1. Defrost time control
2. Open defrost heating element
3. Evaporator fan motor either not running or running to slow.
4. Wiring
Since you did not include a model number and due to the various defrost controls I can not help you. I really need your make and model number to point you in the right direction or to provide you a source for replacement parts.
In the mean time you can get a 2 - 4 day reprieve by doing a manual defrost. You do a manual defrost by performing the following steps:
1. Unplug the unit
2. Remove freezer contents
3. Place a fan blowing air into the freezer compartment for a little over 2 hours. (Makes a mess... rags and Mop time)
4. After 2 hours wipe out any residual water...
5, Plug in unit
6. Reload freezer.
7. Check temps in 4 - 5 hours.
All this will do is de-ice the evaporator coils. (I.e what the auto-defrosting function is supposed to do.) The automatic defrost circuit will most likely have to be troubleshot to return the unit to normal service.
Thanks for choosing FixYa,
Kelly
Sep 19, 2010 | Kitchen Ranges
Whirlpool side by side made in 1998 is not cold. freezer side temp ranges between 32 - 40 degrees at coldest setting. coils are clean. blower is working. could thermostat be stuck or freon low? where do...
Most of the time there is an automatic defrosting problem when the freezer starts warming up. Ice builds up on the evporator coils.. airflow gets restricted and the temps warm up. Check to see that your evaporator fan is running at full speed. If it is then do a manual defrost by performing the following steps:
1. Unplug the unit
5, Plug in unit
6. Reload freezer.
If temps are normal you have an Automatic defrost problem.
Causes can be:
1. Defrost timer / control
2. Defrost Heating Element
3. Wiring
There are other causes but timer / control or the element in a 10 + year old unit are the normal failures.
Do this step before the manual defrost
Make sure that the condensor fan in the lower rear part of the unit is running at FULL speed.and that the condensor coils are free of lint and debris. If the condensor and fan are loaded with lint it will cause warmer operating temps. Clean as needed.
If after you do a manual defrost and the temps come back to normal for at least 24 hours you will need to troubleshoot the auto-defrost circuit. If you need help at that time just respond here and I will help you.
Thanks for Choosing FixYa
Kelly
Sep 18, 2010 | Whirlpool Refrigerators
Not blowing cold air
unplugged the unit, kept the doors closed about 10 to 12 hours plugged back in and in about 2 hours started blowing cold air into freezer another 4 hours was blowing cold air into refrigerator and continuily got back to the themostat settings,about 1 day. no food was lost because the doors were closed still keeping it cold. i think the fan in the freezer was frozen with ice,but could access it, not the main fan in the back the unit by the compressor,that was running fine. so basically i defrosted the freezer fan by unplugging it. this is the 2nd time in 4 years ive done this, well it beats spending 1000-1500 dollars to replace it TRY IT I HOPE IT WORKS FOR YOU BEFORE YOU CALL FOR SERVICE,dave
Jan 25, 2010 | Frigidaire FRS23R4A Side by Side...
Ice Maker does not make ice.
Your water feed to the unit is controled by a needle valve and could be filling up with calcium, to fix this you can take the unit apart and soak valve in a solution that will break down the calcium. Often it is easer to replace the unit or the valve, most things you use to decalcify the valve can also damage it at the same time.
Aug 24, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Jul 26, 2008 | Dometic NDR 1292 Refrigerator
GE GSH22JFR Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
