Question about Xerox DocuColor 12 Color Copier
What does the fault code 116-399 mean? How can I slove it?
Help!!!cant find what fault code means
P4040 code that is a non specific code that could be either EGR control circuit malfunction or security shut down mode meaning that the security system is shutting off the spark and/or fuel.
Sep 20, 2014 | 2001 Daewoo Lanos
Samsung gt e2652 sim lock problom slove?
Hi code are the best solution to remove the sim lock in your Samsung E2652 .To get code visit Unlock-zone.com here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Sep 02, 2012 | Cell Phones
What does the service code p1111 mean?
Copied directly from a Jaguar forum:
P1111 is not a fault code. It is a special designator Jaguar uses meaning system ready, drive cycles completed after the last fault event. P1000, on the other hand, means system not ready, or drive cycles not completed after the last recorded fault event.
Some OBD II Basics - All P0xxx codes are generic and uniform across all manufacturers and mean the same on every car. All P1xxx codes are manufacturer specific codes. You cannot use a generic code chart to analyze P1xxx codes for a Jaguar.
Next time your car displays an engine fault light, try reading the codes then. If you have a CEL illuminated and the only code read is P1000 or P1111, then you probably have a fault that generic code readers cannot see. Could be a chassis code, for example.
One last thing - Neither P1000, nor P1111 can be erased.
Hope this helps you.
May 20, 2011 | Jaguar X-Type Cars & Trucks
Hello any body slove my problem Privacy lock code of samsung gt s3310 i froget it
hello any body slove my problem
Nov 17, 2010 | Samsung Lands Phones
I purched philips dvd player dvp 3126 when iam
what do you mean by 3rd party dvd? is it commercial dvds? is it the region code problem? i mean if you get DVD that does not match with the region code of your dvd player, it wont play.
Oct 22, 2010 | Philips Magnavox DVD/VCR Dual Player
2007 Volvo XC90 fault codes-ECM P030000, P030100, P030300, P0304000, what do they mean?
first code means random/multiple misfire cylinder (s) detected
second code means misfire detected number 1 cylinder, third code, miss=fire number 3 cylinder fourth code misfire number 4 cylinder
causes can be spark plugs, HT leads, ignition coils, injector, wiring fault, low compression/ engine mechanical fault
Jun 04, 2010 | 2007 Volvo XC90 V8 AWD Sport
Please explain error code 000000
how the error code E000000-0000 is solved...give the solution
Apr 05, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
What does h5 code mean?
Hello sir; There have no H-5 error code in the manual, the only chance appear is when you make a automatic exposure adjustment.
Oct 12, 2009 | Sharp SF 2020 Copier
2006 ford explorer will not start - tried to jump start, but no luck
Borrow or buy a OBD 2 scanner and plug it into the Diagnostic Link Connector unfer the drivers side dash. Turn the key to the run position and write down the codes you get from the scanner. Then call Auto Zone or a local car parts store and give them the codes with your make and model. They will tell you what the codes mean and what you'll have to look at next to slove your problem.
Aug 14, 2009 | 2006 Ford Explorer
Xerox DocuColor 12 Color Copier Logo
570 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
