The following message is displayed:
53.11.03 ERROR.
what is the cause and how can it be fixed? pls. advise.
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
