Question about Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard
One long beep tone---NO Display on monitor(monitor checked ok)
One long beep tone and no video display.
checked monitor. checked ok on another pc
  • Anonymous Mar 19, 2014
    pc beeps and the monitor says check signal
    Sniper:
  • 68 Answers
1 Beep (No video) Memory refresh failure Bad memory. Pls change your RAM
Posted on Jun 26, 2009
    President:
  • 2,777 Answers
Definitely not your monitor. It is either a CPU or a Memory problem, is this a new build or did an existing computer suddenly start doing this?
Is that your motherboard, the Gigabyte 7VM400M ?
No display problem for intel D865GSA board
What are you formatting ? Have you changed the RAM. Does tour system work in its original configuration ? You do not say what the pattern of the beeps is. Before the display disappears, is there a message sent to the screen ?
From the manual
http://download.intel.com/support/motherboards/desktop/d865gsa/sb/d5600601us.pdf
Whenever a recoverable error occurs during POST, the BIOS displays an error message
describing the problem (see Table 53). The BIOS also issues a beep code (one long
tone followed by two short tones) during POST if the video configuration fails (a faulty
video card or no card installed) or if an external ROM module does not properly
checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors,
usually consisting of one long tone followed by a series of short tones. For more
information on the beep codes issued, check the documentation for that external
device.
There are several POST routines that issue a POST terminal error and shut down the
system if they fail. Before shutting down the system, the terminal-error handler issues
a beep code signifying the test point error, writes the error to I/O port 80h, attempts
to initialize the video and writes the error in the upper left corner of the screen (using
both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to
the operating system.
18.April.2014
18.April.2014
Apr 18, 2014 | Intel 865G Motherboard
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Inspiron 1501 wont start
Does it look like it is running with the exception of the screen being black?
Does it ever post anything on the screen when you hit the power button?
Beep tones and blinking lights tells thetechnicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lightscontinuous.
Apr 06, 2012 | Dell Inspiron 1501 Laptop
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
Dear my computer not display. i m check the ram .but not display . no beep sound . proper processer fan on and off but not display apper.
Check your video card. Try another monitor that you know that works if it still does not display try a new video card.
Jan 18, 2011 | HP Compaq d530 CMT PC Desktop
Power ok but display not ok
I would suggest that initially you try the monitor on another computer or laptop first to rule out the display itself.
If you are using it on a laptop then just check you didn't accidental switch to another display (FN + F5) cycles through the displays.
If you are using it on a regular computer that has more than one monitor port then try it in the other ports first just in case it is set for an on-board display or in the case of a proper video card that it is not in the wrong port.
If The display is fine on another computer and it does not work on any of the ports then and only then should you look at checking out the display card.
First off you should switch off the computer and remove the card and then re-insert it and then re-check fora display.
Also listen carefully as you switch the computer on.
there may be beeping that would indicate the card itself may be at fault..
May 07, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
thnk you.
Nov 29, 2008 | Computers & Internet
No Beep No Display
Immediately change your motherboard.
Jul 03, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
Jul 03, 2008 | Intel Motherboard
Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Logo
614 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
