240 VAC measured at outlet and light in dryer comes on when door is opened
SOURCE: panel control
Check to see it he belt is good, there is a kill switch on the belt which will stop the operation. Could be a broken belt or bad switch. Spin the drum if it is too easy then it is the belt.
Sgt 48
SOURCE: Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
I have the same indications. It power up intermittently with the check lint LED lit. The manual said it will (lintLED) turn off when the start button is press but only gives me a beep when I press start. Lint LED only turn off when I open door. The dryer will function normally. I disassembled lint assemby and clean it thoroughly, including moisture sensor. I run a diagnostics, all LED lit with 88 displayed on panel. The second 8 flash with a continous beep. I check the power cord and removed panel but have not done a continuity check. The dryer is working now.
SOURCE: kenmore elite quiet pac 9
unplug dryer, then take the top off and check your connections to door switch.i believe this model has a broke belt switch.open the bottom with the machine unplugged and reach inside and see if the belt is broke.if it is then replace the belt.
SOURCE: My kenmore elite he3 electric dryer control panel
The control board is bad. You will have to replace it. You might aslo theck the fuse, sometimes they look a little different than you are used to. Refer to your owners manual and wiring diagram to find it. You can also find more info on the Whirlpool website. Whirlpool makes Kenmore.
SOURCE: dryer does not come on. Light comes on when dryer door is opened.
check the door switch-mike
