Question about Sharp DV-SR45U DVD Recorder
I have a SHARP DV-SR45UC DVD player. Somehow the
I have a SHARP DV-SR45UC DVD player. Somehow the progressive scan mode got turned on and now I can't see any picture. Does anyone know how to turn the progressive scan feature off?
SOURCE: Locked into progressive scan AND Setup is Unavailable
This solution will also work for GoldStar DVR1000! make sure no DVD or tapes are in the player press and hold stop button and it releases you from Progressive scan mode. After searching the web for hours for this model got desperate and was trying fixes for other brands and models, this one worked. Thanks koolanit
Posted on Aug 19, 2007
SOURCE: Sharp DVD disc error
I've found out that the recording speed is important for this model. The speed on the dvd must be 4x or less. If your using an 8x or 16x it will not work. Hope this helps.
Maybe you can help me. I'm looking for the 4 digit code that goes into the remote to make it compatible. I think it's in the operators manual, which I no longer have. If you can find this number I would really appreciate it.
Posted on Dec 18, 2007
SOURCE: How do I turn off Progressive scan?
Progessive scan DVD
Read the following :-----
Caution
Once the setting for progressive scan output is entered, an image will only be visible on a progressive scan compatible Tv. if youset it in error,you must reset the unit. Pointing the remote at the player, press the STOP key tostop any disc that is playing. Next, press the STOP key again and hold it for 5 seconds before releasing it. The video output will be restored to the standard setting, and a picture will once again be visible on analoge TV
Posted on May 09, 2008
SOURCE: DVD player wont show picture
take the dvd out and hold the stop button on the dvd player for 5 sec (not the remote) the dvd player and that will work
Posted on May 20, 2008
mjjdesigns
  • 98 Answers
SOURCE: Can't turn off progressive scan on my dvd/vcr player.
Page 18 of the operating manual cites this, to reset to default viewing mode:
1) Remove any disc from the unit and close the disc
tray. See that “dISC” is displayed on the display
window.
2) Press STOP and hold it for more then five
restored to the standard setting and a picture will
once again be visible on a conventional analog TV or
monitor.
If that doesn't work, please let me know.
Posted on Mar 19, 2009
Tip
Pioneer DVD-400V HDMI Reset Model: Pioneer DVD-400V To switch your Pioneer...
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and losing picture, follow these steps:
  1. Switch everything off.
  2. Switch the player to standby.
  3. Press and hold the Standy/ON button while pressing the |<< button.
This resets your Pioneer DVD-400V player HDMI output format to 480p.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V Interlace Reset
on Jun 06, 2010 | Pioneer DV-400V DVD Player
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
Progressive scan, no pictures on tv
Hold down stop button and turn on standby button this will reset to normal mode.
Mar 12, 2009 | Pioneer DV-270-S DVD Player
Progressive scan
I had the same problem once and the solution is to reboot the DVD player. to do this you need to unplug the unit for 3 or more minutes and then you will have to go through the setup process again but everything should work fine and interlaced (not progressive) should be the dvd format again.
Feb 05, 2009 | Toshiba SD-V392 DVD Player/VCR
Cannot remove progressive scan mode
I turned on the dvd player and pressed down on the play button and counted to 10, but before I got to 10 the progressive light went of and the image on my tv set came back on.
Mar 29, 2008 | Sanyo DVW-7100A DVD Player/VCR
RTD 155 - only black and white...no color
Perhaps you have set your DVD player for Progressive Scan Mode while your Television does not support for the same. Go to the setup menu and turn Progressive Scan Off. This will solve your problem.
Feb 04, 2008 | RCA RTD155 System
Progressive scan
lpug ur dvd. without turning the power on press and hold the stop button then press the power button
Sep 22, 2007 | Pioneer DV-373 DVD Player
Insignia dvd/vcr combo progressive scan mode
turn on dvd, make sure the disk is out, press and hold the stop button for 5 seconds and it should go back to the picture
Jul 04, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
I can not turn off the proggressive scan!
Try this to disabel the progress scan mode: Pointing the remote at the player, press the STOP key to stop any disc that is playing. Next, press the STOP key again and hold it for five seconds before releasing it. This should turn the Progressive Scan off.
Oct 05, 2006 | Zenith XBV442 DVD Player/VCR
Sharp DV-SR45U DVD Recorder Logo
114 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
