Cannon 8400 shuts down after each print with hardware error code 03130031-2f26
SOURCE: P8 error code on cannon mp260 cannot get to print
The
8 error code just means that the ink absorber is full and needs to be
replaced. Power cycling will not help this problem. You need to
replace the absorber and reset the counter
http://erkinson.altervista.org/stampanti-canon-codice-errore-lampeggi-led/
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
Thank you for using Fixya
