Question about Dometic Rooftop RV Air Conditioner
The fan of my ac home unit, doesn't start. I hear the noise and the fan start moving slow but doesn't go thru. I rmove the fuse, make some rounds to the fan, after that I plugged the fuse,and sarted working and cooling normal. but after 2 hours, stop and I've the problem again.
  • ruben4life Jun 26, 2009
    Absolutely right.
    I am working to fic the unit.
    Sincerely
    Ruben
    Absolutely right.
    Sincerely
    Ruben
    President:
  • 1,734 Answers
Most compressor units have a double capacator . If one half goes bad, either the compressor will run without the fan, or vice versa. Those big capacitors can be nasty. First step on any system with capacitors is to short them out. Use a plastic handled screwdriver. Touch a blade to one terminal of the capacitor and pivot it to touch the other. Do that with each one. Mid range Multimeters do not work well checking capacitors. Best thing is a good one with a capacitor checking function. Follow directions. With a cheap analog meter, put it on ohms and connect the leads while watching the meter. The needle should swing toward 0 initially and slowly creep back to infinity. Most air conditioners have a double capacitor in one case. It is almost quicker to check both than identify the one for the fan. If the motor turns freely and does not look obviously burned and the capacitor checks bad, likely it is bad and may well be worth replacing even on such an old unit. An Dometic dealer or an electrical supply house may be the best place to check for a new one. Just take the the old one in and let them match it up. I am not sure about that SuperBoost (brand name) relay and hard start capacitor. If it is bad, try removing it, and see if starts without it. Otherwise, maybe a friendly supply house will help you.
USA
SERVICE OFFICE
The Dometic Corp.
2320 Indust. Parkway
Elkhart, IN 46516
Phone: 574-294-2511
CANADA
Dometic Corp.
46 Zatonski, Unit 3
Brantford, ON N3T 5L8
Canada
Phone: 519-720-9578
Posted on Jun 26, 2009
FAN NOT PUSHING AIR THRU ON AIRCONDITIONER OR HEATER
If u don't hear any engine noise when u turn on fan u have to check fuse fan .otherwise u must check the air flaps ... same cars has activate by air pressure .... but if un hear fan maybe the fan`s pallet its loosed ...
Nov 20, 2014 | Cars & Trucks
Why is one 30 AMP fuse pair blowing on Carrier Tech 2000 SS AC Unit?
Pull off one of the wires to the fan. If it still blows a fuse the compressor is shorted. If not replace the fan motor.
Jul 03, 2014 | Carrier Heating & Cooling
Cool air from home vents with central AC outdoor unit fan will not turn on. Inside home really loud when on!!
its look like blower problem , 1st check blower speed controller, check blower motor , check its ball bearing etc , its does not have any link to external unit .
Jun 15, 2014 | Goodman Heating & Cooling
Filled Coolant reservior and radiator Drove trailblazer at highway speed no cooling problem. When slowed down in traffic temperature increased to about 220 and higher, could hear coolant bubbling in...
If there is bubbles occurring even inside the top part of the radiator (where you have the coolant put in), you may have a leak on your head gasket. You may be loosing coolant through the engine.
Sep 15, 2011 | 2004 Chevrolet TrailBlazer
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
The compressor on my ac unit at home is not working. I can hear the motor on compressor running but the fan is not moving..ideas?
Replace the condenser fan and capacitor on the unit. The capacitor is the starting component for the fan.
Jun 08, 2011 | Heating & Cooling
In home fan puts out air thru vents however the model38ckc060370's fan stopped working and no ac flowing through unit to cool house. Is there a simplle trouble shoot for my problem?? The unit is 7 years...
Make sure circuit breaker for the outside unit is on or the fuses are good whichever you have. If they are on you can check the capacitor in the outside unit. The capacitor will be a round or oval can and can be metal or plastic. You can also look at the contactor to see what shape it's in.
May 03, 2010 | Carrier 38CKC060 Air Conditioner
I have a cple18-1c at my home. it is making a
Fan motor is out or possibly the capacitor to the fan is bad. Would have capacitor replaced first then replace the motor if the capacitor didn't solve you problems.
Good Luck on repairs
Dave
Dec 08, 2009 | Goodman CPLE24-1 Air Conditioner
Air condition fan noise !1
go back to it an check the fins they may be rubbing on the cover.
May 27, 2009 | 2004 Honda Accord
Dometic Rooftop RV Air Conditioner Logo
32 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
