Water is running out of the bottom of the unit. I have had the unit less than a year and the company went out of business. Can you help me?
  • Robotinner May 11, 2010
    little more specific insdie unit or outside
  • 38 Answers
If it is the indoor unit that the water is running out of you can go outside and find the 3/4" pvc either coming out of the ground, or from the wall, that is you drain line.
Take a wet/dry vac and **** everything you can out of it, leave the vac on it grab a beer and come back, if a clog is present it should be unclogged.
if it is the outdoor unit water is coming from that is normal don't worry, the manufacturer builds thm to drain from the bottow it's fine
Posted on Jul 01, 2009
How Long Do I Have To Be In Business?
The majority of leasing programs require not less than 2 years of time in business. However, start up business programs is suitable for individuals companies who've been running a business for under 2 years.
Oct 20, 2015 | Retail Supplies
Is there any software that similar to hzd4b that will work with my hammer storage box and can run on windows 8.1
Hammer went out of business quite awhile ago. You would have to find the manufacture software for that particular unit which will be difficult given that the company is no longer in business.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/aaron_eefc4ebb3e929c59
Jul 07, 2015 | Computers & Internet
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
We purchased a Heritage ceiling fan from our local K-mart about two weeks ago, we installed it today and it makes a VERY loud noise in the engine when we turn the fan on... We went through the trouble...
sorry but the company went out of business years ago. The only thing you can do is let it run, The heat from movement will warm the grease and dispers it. The unit is " kinda ceased " do to lack of sales, because there very low end.
Mar 11, 2011 | Garden
Bottom freezer is fine but top refrig. is warm. Have vacumned bottom front coils, unit less than 2 years old. Any suggestions, other than calling repair? thanks.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Amana AFF2534FE Bottom Freezer French...
My son's car overheated. Went to get some anti
The overheating is caused by the sludge. It is very easy to correct this problem. Remove the radiator cap and open the drain valve at the bottom of radiator. If possible, remove the reservoir and flush out with water. Make sure to get all sludge out of reservoir, then reinstall. Once the radiator stops draining, insert water hose (without nozzle) and turn water on. Keep the drain valve open. Run water through radiator until it runs clear. Once it runs clear, start the engine and let it run while keeping the water running through radiator. Allow engine to run until the thermostat opens up. Continue running water through radiator with engine running until the water from drain runs clear. Once you have done that, turn off the engine. Close the drain valve and refill radiator with proper mixture of coolant and water. Once radiator is filled, start engine and let circulate through engine. Coolant level will drop as the coolant starts circulating. Shut off engine and top off radiator. Fill the reservoir with the required amount of coolant. Testing the coolant at least once a year will help prevent this from happening again. Coolant should be replace a minimum of five years, less if coolant bottle specifies.
Jun 20, 2010 | 1994 Pontiac Grand Prix
My new macbook dont read the Nixveu digital album lite. how can I resolve this problem?
You may be out of luck.. The company that made it went out of business about 4 years ago. The mac software they had was for OS9.1
Googling the unit didn't help much either.
Jan 12, 2010 | Apple MacBook Pro Laptop Computer with...
My Gibson Furnace clicks on but no heat comes out.
After four years I do not thing you have an effective warranty even if the company still in business. you need to open it first and clean it from any builod up dust and check the switch to see if it is working (thermostate)
Nov 08, 2009 | Heating & Cooling
DH runs but does not condense any water out of the air (bucket is dry). This unit was working well until a week or so ago when we had a lot of T-storms and humidity rose considerably. We went from having...
there are coils in the unit that the water folws across, you can take the filter out and clean the coils, this would help,but even though it is only 1 year old it can go bad,, if it is clean inside and everything is appering to be working it might have just gone bad and n eed a new one
Jun 28, 2009 | Frigidaire FDL25P1 Dehumidifier
Solor pool pump problem
Hi richkline1,
I'm Harvey the Master Plumber.
Your problem is: You have a 3/4 horse pentair pump. it was pre-plumbed by your pool builder who is now out of business. You installed your solar heater yourself and when you originally installed it on your roof aprox 12 feet off the ground you did not put a check valve after the pump. The basket will no fill with water completely but there is water flowing. there are two inlets in the bottom of your pool and you can barley feel the water coming out of one. before the company went out of business they told you the since you didn't install the check valve after the pump that the back flow of water into the pump has caused the pump now to run in reverse. doesn't sound right to you. they said the something needed to be replaced and they would send someone out. they never did. any thoughts?
I've been thinking about your situation for a few days. First install the check valve. If the problem persists then I would suspect the pump. I have seen a few times that the pump was not the problem. In these cases it was something I call an air lock. It is dificult to explain to the layman but it can be responsible for the lack of flow. It has to do with the way it is piped. I know it seemed simple to pipe but if not done correctly you have this kind of headaike. To solve this I would have to be there. Wish I could do more.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 20, 2008 | Home
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
