Question about Magellan GPS
Magellan explorist xl gps when i turn it on the back light comes on but the unit does not boot up i have tried taking the batteries out when lit up, no effect the unit is a few years old but very lightly used also when like this you cant turn off using the button again you have to pull the batteries
    President:
  • 1,383 Answers
You can find there is 1 reset button on GPS .press it then all settings set to defaults.
Alsoc oonect it to computer with usb cable then check it is found scan your memory card with antivrius.
Al;sop you can update firm ware from this site.
http://www.magellangps.com/support/product.asp
seelct your model from here then update firm ware.
Posted on Jun 26, 2009
My gps magellan explorist 510 cannot open up after ppower on.
From your question it appears that the unit has some corrupt internal memory files. Please return the unit to Magellan. JG
Jul 09, 2014 | Magellan eXplorist 510 GPS Receiver
When powered up, unit only displays
May have gotten salt water in it and causing shorts, needs to be disassembled, cleaned and dried out carefully..... The corrosion film is almoner invisible and the small surface mount parts can suffer from small amounts.....
Feb 14, 2010 | Magellan eXplorist XL GPS Receiver
Hi Guys: On turning on my explorist 400 a message appears. UNIT CURRENTLEY CONTAINS NO MAPS! INITIATING MAP UPLOAD This message wont go away, and all buttons refuse to work. The only way I can turn it off...
Jeff, I had the same problem with my explorist 500. Your unit lost the "BASEMAP.MGI " file. You will need to get a copy of that file. Then install it.
Try this site http://imhz.com/2006/05/my-explorist-is-screwed.html
(I would recomend all explorist GPS owners copy and save that file and store it in a safe place. I have mine on a thumb drive).
Dec 05, 2009 | Magellan eXplorist 400 GPS Receiver
No drivers avalible for magellan Explorist 500 for Vista 64 bit
Windows 7 has a windows xp mode that seems to work. I have been using a VMWare image with windows xp for cranky hardware like my explorist xl.
Apr 05, 2009 | Magellan eXplorist 500 GPS Receiver
CAN NOT GET MAP ON GPS MAGELLAN EXPLORIST 210
try updating the firmware from the magellan website that fixed mine.
Oct 29, 2008 | Magellan eXplorist 210 GPS Receiver
My eXplorist XL is locked up
Error message at start-up reads: "Press ENTER to continue NAND, Press ESC to cancel". Either choice I seclect and the unit shuts-down.
"With you XL turned off press nav + power; then change the numbers in the box from 00 to 95 by using the joystick and then press the joystick itself; (ENTER), accepting what is proposed...
Either FORMAT or SCAN... LET IT RUN!
After turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. Your system will immediately start to re-set itself.
If necessary, in usb file transfer mode, reload the basemap in the directory background maps..."
The only difference is that I had to load my SD card in the unit for it to work during the FORMAT.
My unit is NOW re-booting back to normal!
Sep 02, 2008 | Magellan eXplorist XL GPS Receiver
Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
Feb 24, 2008 | Magellan eXplorist 500 GPS Receiver
Explorist 500
i had the same problem you have to contact magellan and they will tell you it needs to be sent in for repairs and they will send you an email or give you a phone # for the closest repair center to you
check this link for the magellan technical support closest to you https://www.magellangps.com/about/contacts.asp
Oct 19, 2007 | Magellan eXplorist 500 GPS Receiver
GPS Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
