It seems my deco is unbalanced, work perfect if I take out the bobbin casing and bobbin, but the moment I put it back it breaks needles and make a very loud noise then com to a standstill. Please help
SOURCE: Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
SOURCE: Needle/Bobbin issues with Bernina Deco 600
Jim!
Perfect phrasing of the question, you have all the lingo/parts down pat!
First make sure your new needle is straight, then check to make sure it lines up in the center of the hole in the stitch plate.
There is basically a 1/2 sheet of papers (we use the fine waxy sticker backing paper as our guages don't fit well .1mm! ) distance between the hook and the needle.
Rotate your hook so that it is aligned with the needle in the center position, there should be 2mm between the top of the needle eye and the bottom edge of the hook.
SOURCE: Just got my used Bernina deco 650 from the shop. Tension off
pshawver is correct, I have 40 years experience working on sewing machines
