Question about Kenmore Washing Machines
Mold build up between drum and sleeve. - Kenmore Washing Machines
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Tip
How to Stop Mold or A Stagnant Smell from Washing Machine.
If your washing machine is producing a stagnant smell which is tainting your clothes then this Tip is for you!
Secret ingredient: Ordinary Baking Soda.
First check to make sure that the machine is draining properly and ensure that the pump filter is clear of any debris. Check that the drainage pipes at the back of the machine are not kinked or obstructed in any way.
If the machine is a frontloader a common place for mold to build up is the rubber seal gasket around the door such as this one. Immediately you can see the nooks and crannies where mold can build up.
Mold is one of the most common causes of a stagnant odour.
Clean this out as well as you can with ordinary kitchen cleaner (avoid using bleach) then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Baking soda has a cleaning and neutralising effect and will help remove any build up of mold or gunge within the machine. You may need to run two of these washes before you see a solid result.
Thereafter I recommend you run a monthly 'maintenance wash' with the baking soda to prevent the problem arising again.
It is highly recommended that the door of the machine is always left partially open between washes as this encourages ventilation and discourages any more mold from forming inside the machine.
If you found this Tip helpful please take the time to register your vote using the buttons below.
Many thanks for using FixYa.
on Dec 19, 2009 | Washing Machines
SHARP AR-160 not printing properly only on the bottom middle section of paper
Pull the drum module, remove the drum and check for toner, dust build up in cleaner catch area. Check for even developer distribution on developer sleeve.
Check fuser after that.
Mar 01, 2011 | Sharp AR-160 Copier
Gasket seems to have pulled away from "drum" side;
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Jan 25, 2011 | LG WM-2277HW Front Load Washer
Was cleaning rubber gasket for mold and noticed when I cleaned inside outer lip of steel drum a lot of brown sludge-is this grease for drum or is this build-up of some sort that should be cleaned? Also-do...
The brown sludge you are finding should NOT be grease as the bearings for the drum are sealed. This may be soap scum build up, and a combination of mold or mildew if you have been leaving the door shut between washes. It is strongly recommended by the manufacturer that you leave the door open when not in use to allow the drum air out. This aids in preventing mold, mildew and odors. The following link explains some of the common causes of front loader odors and how to remedy the problem:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
As far as the water fill hoses are concerned, the hoses are usually good for about 5-10 years (rubber), 10-15 years (stainless steel). They usually only require replacement if the rubber begins to crack or dry rot and/or begin leaking. A general inspection of the entire length of hose, cleaning the sediment screens in the ends of the hoses (if equipped) and replacing the gasket at the fitting will extend the life of the hoses. Replacing the hose has nothing to do with preventing odors. Odors are generally caused by not leaving the tub open to air out, using too much (or improper) detergent which causes soap scum build up, or a clogged drain trap. The following link explains how to access and clean out the drain trap:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
I personally own a washer similar to yours and have never had any problems with mold, mildew, or odors, by following this regiment. If you have any questions or concerns, please post back and let me know. I hope you find this information helpful.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After washing my machine smells like stagnant water
Hi
First check to make sure that the machine is draining properly and that the pump filter is clear of any debris.
If the machine is a frontloader a common place for mold to build up is the rubber seal around the door. Clean this out as well as you can with ordinary kitchen cleaner then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Hope this helps. Thanks for using FixYa.
Sep 26, 2009 | Whirlpool Washing Machines
Mold build up around rubber in washer drum. Can
Buy affresh washer cleaner. You can order it over the internet and this should take the mold off and then if you use this regularly like the package explains it will keep the washer from molding. I use this stuff on all the front loaders that come into my shop. This stuff works great.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Water won't drain from washing machine
the water or liquid you hear when you spin the drum is not from washing it's suppose to be there to balance the spinning of the drum.
Aug 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Mold in Washer Dispenser Drawer
The washing machine drawer keeps building up mould,this video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
FREE question.
Jan 24, 2008 | Washing Machines
Washing Machines Logo
85 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
